Manual Transmission - NewBeetle.org Forums
Go Back   NewBeetle.org Home > NewBeetle.org Forums > NewBeetle.org > Suggestion Box
Suggestion Box The place to offer your suggestions, comments, criticisims, and such for NewBeetle.org.
Old 08-29-2009, 04:44 AM
Default Manual Transmission
I am trying to find out the procedure on checking the fluid in a manual 6 speed transmission and how to add to it if need be .
Is there anyone who has done this or has any information to share .
The car in question 2003 VW Turbo Beetle 1.8
Old 08-29-2009, 03:29 PM
OH, USA
Car: 03 GTI
First, it takes a special tool , used to be just a 17mm hex but they changed it. Look underneath the tranny you will see a plug that has a star pattern recess with a nipple in the middle (safety torx I believe they call it) that is the drain, on front about 1/2 way up you'll find an identical plug--with the car level, remove that plug, 75W90 synth should be up to the bottom of that hole--just drip out--when there, the level is correct.
Manual Transmission Won't Go Into Reverse - Help! Jon Lloyd Transmission Talk 8 05-22-2011 02:21 PM
Manual Transmission Problems!! JoDiazz Questions, Issues, Concerns, or Problems with the New Beetle 4 09-10-2008 09:35 PM
Redline MTL or MT-90 for Manual Transmission? [lot] Transmission Talk 3 08-14-2008 04:13 AM
2.5L 5L 6 speed manual transmission? brycastillo 2.5 Liter Gas 3 03-23-2008 03:55 PM
2.5L 5L 6 speed manual transmission? brycastillo Transmission Talk 0 03-23-2008 01:30 AM
