Cabin Air Filter [change it !!] - NewBeetle.org Forums
Go Back   NewBeetle.org Home > NewBeetle.org Forums > Community > Event Announcements and Planning > Tail of the Dragon
Tail of the Dragon Come tame the dragon with the New Beetle.org and help make it a great annual event!! As this is a multi-region event please put all posts here.
Old 10-09-2010, 06:39 PM
Cliffnotes's Avatar
Kings Mountain, NC, USA
Car: 2003 Turbo S
Exclamation Cabin Air Filter [change it !!]
As the proud [new] owner of a 2003 Cyber Green 1.8T S; I quickly noticed a cabin funk that can only be described as: "Waxy Crayon Box".
Armed with a new STP Cabin Air Filter [part no. CAF7702] from the local parts store I proceeded to operate on the right side of the dashboard to access/change-out the old one. You'll probably discover LOTS of debris and fotch when you get to it but found it a -very- easy operation that folks should not be scared of.
DO make sure to have a vacuum handy to suck up the debris before removing the old filter and set the climate control button to "recirculate" before turning off the igintion key[the lighted button with the looped arrow next to the lighted A/C button] since that will also protect the fan blades from trash being dropped down into the chute underneath the cabin air [or some call it the "pollen"] filter. If you don't remember when yours was changed last, you probably should do it some time when you have 45 mins [first timers] or so.
Here's How:
How To - Cabin Air Filter Replacement
It's helpful to have a 'magnetic parts bowl' handy to keep the screws in while you work, otherwise the operation is pretty straight forward and easy, not to mention inexpensive.
How To - Cabin Air Filter Replacement salsa-man Technical How-To 12 09-16-2011 10:51 PM
How Do I Replace The Cabin Air Filter? iddqd Questions, Issues, Concerns, or Problems with the New Beetle 4 11-04-2010 03:49 AM
Changed out my cabin air filter today akasha1963 2.0 Liter Gas 12 03-16-2009 06:39 AM
Cabin Air Filter Danbike New Beetle Convertible 3 11-16-2008 04:51 PM
How do I replace cabin air filter??? jiggseob Questions, Issues, Concerns, or Problems with the New Beetle 5 11-07-2006 03:41 AM
