How To Fix A/C Fan Switch - Page 2 - NewBeetle.org Forums
Go Back   NewBeetle.org Home > NewBeetle.org Forums > How-To's > Technical How-To
Technical How-To Step by step threads showing you how to perform various technical and performance related tasks.
  #21 (permalink)
Old 07-31-2008, 01:56 PM
I do have the photos! I just did this to my bug two days ago and took the pics while I was at it, but I can't post them today while I'm at work. If you PM me I'll try to get them to you sometime in the next few days.
Having just done this, here is what you need to do:
1) slip top front dash piece forward, up, and off
2) remove radio (you can use bread knives or something the right size if you don't have the wrench)
3) disassemble the dash one piece at a time. The bolts on them all are pretty straightforward, just keep looking around.
4) When you have access to the fan switches, you'll be able to see the mechanism at work behind the speed control. The plastic tube from the switch goes back and fits into a circular dish. a metal piece clips into the dish and when you rotate the knob, the metal piece slides along another metal receptacle, thus making the connection.
The problem is that the metal piece comes unclipped from that plastic dish - it's just a bad design. If you super glue the two parts together, it will be much better than new. Mine now works perfectly. Takes less than an hour.
  #22 (permalink)
Old 11-21-2008, 04:00 PM
Ontario, Canada
Car: 2000 red Beetle
Just need to send a thank you for this DIY on the fan switch. Mine went on me after I replaced the bulb. You really have to pull out the fan switch in one motion, with finesse, otherwise that little bimetal arm just shakes loose. We just got a foot and a half of snow in Southern Ontario, and I'm out in the driveway(with a portable heater in the car) fixing this problem in my wive's car. Getting that little metal arm bent back just right so it makes contact properly took a little doing. Must've tested it 8 times before I got the switch to work on all 4 speeds.
Anyways, I just want to thank the people responsible for this little fix. Props.
  #23 (permalink)
Old 11-22-2008, 10:56 PM
GatorBeetle's Avatar
Wendy 1974-2008 :(
Salisbury, MD, USA
Car: '06 RS GLI 6-Spd
Glad to be of help after all the times the ORG has been there for me. I cant take credit for the original thread, but I did keep it alive...pay the love forward!!!
Wendy Rotar 1974-2008
Online Memorial & Guest Book
  #24 (permalink)
Old 01-02-2009, 07:16 PM
Just did this on mine. Thanks for the pics!
  #25 (permalink)
Old 01-02-2009, 07:20 PM
Wendy 1974-2008 :(
Salisbury, MD, USA
  #26 (permalink)
Old 02-07-2009, 12:29 AM
99 TDI Beetle & 02 Jetta
I just fixed my Fan Switch but..... My switch was melted
I picked up a Jetta Switch and used the black plastic piece with the contact in it as a transplant part.
Works fine now. Just so you know the Jetta part that you see the Numbers for fan speed is slightly Larger than a Beetles. But the inside part is the same.
1999 TDI New Beetle and 2002TDI Jetta
  #27 (permalink)
Old 03-02-2009, 08:05 PM
fwiw,
someone on ebay has these 3-control units for $50ish. Look for seller carmella555555 .
I just bought one of these. Haven't installed
it yet, but it looks pretty good.
Lowell
  #28 (permalink)
Old 04-04-2009, 04:45 AM
mgwerks's Avatar
Cherchez la coeur...
Bandera, Republic of Texas,
Car: Oso - a black 99 GLS TDI
Gator,
It's been forever since I logged on, but I still know where to turn for the best help. Thanks for resurrecting this post. My wife's switch died last week and it's already hot in Texas! Anyway, I just finished reassembling the switch and testing all the positions with an ohmmeter - all is well.
Points to you!
Mark
Your fog lights are on,
It isn't foggy today -
You are a doofus.
  #29 (permalink)
Old 05-17-2010, 06:00 AM
This thread just saved me a couple of hundred bucks...
Thanks!
'99 Fan Switch Problem russ42824 Questions, Issues, Concerns, or Problems with the New Beetle 5 09-02-2010 07:31 PM
Fan Switch and A/C rob11g Questions, Issues, Concerns, or Problems with the New Beetle 2 08-03-2010 12:29 PM
Quick fix? EvilinaDM101 Styling Modifications 2 03-27-2006 04:41 AM
Not Broken but I want to fix anyway..... Sambeaux 1.8 Liter Turbo 9 03-12-2006 08:56 PM
on off switch for electric fan? jazzcat 2.0 Liter Gas 13 01-16-2006 02:45 AM
