| Technical How-To Step by step threads showing you how to perform various technical and performance related tasks. |
| View Poll Results: Do you change your own Oil? | |||
| Yes, of course I change my own oil/filter |
170 | 74.89% |
| No, I have a VW dealer change oil/filter |
21 | 9.25% |
| No, I have a Independent Mechanic change oil/filter |
18 | 7.93% |
| No, I use Jiffy Lube/Grease Monkey (etc..) change oil/filter |
15 | 6.61% |
| No, I have a BF/GF (friend) change my oil/filter |
3 | 1.32% |
| Voters: 227. You may not vote on this poll | |||
Hey gang,
I thought that I would put this information out as a public service announcement to our general VW community. Lot's of supporting information below, but the bottom line is a bigger oil filter for "ANY" small engine is a good thing. VW makes a larger filter that will fit our 4-cyl engines (1.8t, 2.0, 2.5) and provides almost a full quart of more oil. This is the standard one-piece large capacity engine oil filter from VW which fits the 20mm thread and has the exact same ring seal diameter (most important fact) as our current filters. The OEM filter manufactures for VW are Mahle & Mann. This is the oil filter that VW is now requiring all dealers to use when working on the B5 and B6 platform's (Passat/A4's plus TT's, certain GTI's, Golf's and Jetta's) based cars with the 1.8t engines. This information was released via VW Technical Bulletin #04-01 Group 17. If we have any VW tech's, and they have a copy of this, it would be cool to post it here (thxs). Main reason for this tech bulletin was that these cars were designed with a smaller wetsump which contains less oil (4.5 quarts vs. 4.8 quarts). The lower volume of oil has lead to a high number of heat related engine failures. So, we benefit, yeah!! I personally have found these new filters via ECS Tunning's website (http://www.ecstuning.com/). They offer them individually or in a 5-pack or 10-pack group. I am sure you web-savvy folks can find numerous other suppliers, and if you do, please post those links here (thxs). My personal experience with the larger filter has been good. Fits in the OEM area without problem, oil pressure run lower the before, and when I did my first oil change, the oil comming out of my 97,000 mile engine looked better than when it did at 20,000 miles. Here is a very good write-up regarding the benefits of using a larger oil filter with smaller engine. This was written completly independent of any manufacture biased, so this is just basic good car maintenance/performance practices. Also, the same upgrade can be accomplishe with non-VW filters, but you will need to go through the trial and error process of finding the right FRAM or DELCO filter that will fit the space provided. If someone does this, or already has done it, post back the manufacture and part number info. Cool.. .Quote:
Take care of your pod and your pod will take care of you....TechnoTrix'd.... ![]()
Hey Click ME! – ToD 2K12 GTG & Cruise - - -ToD North East Bugavan Thread 2k12 Previously Owned Vdubs: '83 Blk GTI (Da' Bomb - moon-roof, ball shift knob, crazy striped interior), '87 Vanagon (Weekender - Brown), '90 Vanagon (Weekender - White, alloys, - one style'n refrigerator on wheels), '08 Graphite Blue Passat LUX. Last edited by marvins_dad; 01-15-2007 at 02:33 AM.. |
Any VW dealership will carry them, but they won't be open on a Sunday. I'd just order and do the change next weekend, my 2cents. BTW, you might want to think about that comment above. I have three daughters and each one will be able to change a car's oil and replace a tire before they drive. Trust me, being a "guy" does not provide you an exclusive genetic "mechanic" gene... ![]() TechnoTrix'd..... |
Not to down Jiffy Lube ... they may be the best ... and they are a local company, heck the guys that started it graduated from my high school a 2 years before me. But I don't let anyone else feed Silver.
As for the filter, some of us have known about this for a while, I use a K&N or Mobil1 filter, but some of my GTI buddies use one from I belive a VR6 engine, it is not a whole quart larger ... it is a whole quart that it holds ... so 1/2 quart more oil. |
I have a dealer do changes on the wifes beetle.
but, for the record, she has done oil changes and more on some of our other vehicles. she likes to get down and dirty and the knowledge she gains by actually turning a wrench and asking questions, keeps her from getting taken at any dealer or repair place that she inevitably needs to take a vehicle to. If they give her a line of BS, she's likely to realize it and call them out on it. ![]()
I said what?!?!?!?! |
The reason the Passat and Audi A4 1.8Ts are recommended to use this filter is because they were experiencing oil sludge problems due to higher temps in the engine oil because they (from what I've heard) carry .8 quart less oil--so adding this filter still doesn't even bring the capacity to what we have in our NB 1.8Ts. The Passat/A4 engine is mounted longitudinally (front to back) versus tranversely (side to side) as in the Jetta/Golf/Beetle and the oil pan has to clear a cross-member. I have seen the TSB specifying the filter for Passat/A4, but not for others--and my dealer says it isn't on all 1.8Ts. It's a good idea for sure anyway, especially if you are modded. I'm not going to rush out and switch over though--at least until my supply of filters are gone.
UPDATE:
We took her beetle in for an oil change at the dealer today. After a few minutes of "discussing" the installation of the Passat filter, they grudgingly agreed to install it. First, the service guy said they couldnt do it, and he had never heard of such a thing. I asked for "someone slightly smarter", and he fetched the service manager, who said it had a different size gasket. After informing him that the gaskets were indeed the same size, he said that he couldnt do it due to warranty issues. After agreeing with me that at 41K miles my car was indeed out of warranty, told me he would talk to the tech about putting one on. End of story, they installed the big filter, and on the invoice it actually says "INSTALLED PASSAT OIL FILTER". So I guess this can be done at the dealer, just might require some "convincing".If anyone is interested, the number on the filter is 068-115-561-B ![]() |
If any else experiences an equaly clueless service department, have then bring out both filters, and show them yourselves that the seals are in-fact, the same size. Way to go Dan, nice work educating the dealership.. ![]() TechnoTrix'd.... ![]() |
| Is this 2.5 a version of the old Audi 5 cyl.? | bockegg | 2.5 Liter Gas | 22 | 08-14-2006 04:02 AM |
| Drainback Oil Filters | vwdriver | 1.8 Liter Turbo | 1 | 04-14-2006 10:44 PM |
| oil / filters | electraglide | The Canada Corner | 1 | 01-03-2006 12:26 PM |
| FS K/N Filters | Buglover | Market Place Archives | 15 | 11-14-2005 02:46 AM |
