| Technical How-To Step by step threads showing you how to perform various technical and performance related tasks. |
How-To by BugMod.com
Photo's and Info by: VWVWVW/VWMike/NETBEETLE Written by: NETBEETLE New Beetle 98-02 Factory SnowBox Removal All of our NB's come delivered from the factory with an air-intake contraption that is quite difficult to understand called the SnowBox. This unit is VERY restrictive to the airflow feeding the engine and seems to do more harm than good. Let's get it out! Tools needed for this Mod: Jack / jack stand / wheel blocks Factory lug wrench / wheel lock adapter TORX Driver set Metric socket set Torque wrench (if available) Approximately 90 minutes labor time The first step in the process is to loosen the lug nuts on the front, driver's side wheel and jack-up the front, driver's side of your NB. Make sure you use the body rail as your jacking point (NOT the rocker panel). Once your safety jackstand/wheel blocks are in place, remove the lug nuts on the front, driver's side wheel and remove. Our next step is to remove the wheel well liner. Locate and remove the 13 screws that hold the liner in-place with your TORX Driver. There are five screws on the inner liner (see picture below), and the rest are located, just to the inside of the fender lip around the radius of the wheel well.
That's it! To complete the mod, simply reverse the process for re-installing your wheel well liner and mount your wheel. One important note: make sure you stop and see your local mechanic to have your lugnuts tightened with a true, torque wrench (80ft/lbs torque recommended). You're now ready for a Ram-Air system! The BugMod 3" Ram-Air CAI Systems are currently available here: BugMod 3" CAI Ram-Air Systems.
To discuss this How-To please visit the link below...
SnowBox Removal - (How-To) -Discussion Thread<---click here |
| 06 headlight removal | yelojkt | 2.5 Liter Gas | 19 | 06-13-2011 03:30 PM |
| Anyone has pictures of what the snowbox is? | degny21 | Technical Modifications | 39 | 05-05-2010 01:18 AM |
| Removal Tools | MOONDOG316 | Car Audio | 1 | 01-10-2006 10:53 PM |
| center cap removal | FineExampl | Styling Modifications | 2 | 11-23-2005 01:03 PM |
| seat removal | nbdude | Questions, Issues, Concerns, or Problems with the New Beetle | 0 | 10-15-2005 07:41 PM |
