HOW TO: Hazard Relay Replacement (turn signals and hazards not working) - Page 2 - NewBeetle.org Forums
Go Back   NewBeetle.org Home > NewBeetle.org Forums > How-To's > Technical How-To
Technical How-To Step by step threads showing you how to perform various technical and performance related tasks.
  #21 (permalink)
Old 03-15-2008, 11:37 PM
I've been buggered.
Timbuktu, NH, USA
Originally Posted by jthrash61
I have to replace my hazard relay. Do I need to disconnect the battery?
Nah just do it.
  #22 (permalink)
Old 03-23-2008, 04:53 AM
Jenne's Avatar
Columbia, MO, USA
Car: "The Tardis" 1999 Black GLS
I'm bumping this so I can find it again when my hazard switch comes in. I had this problem today (still intermittent... it started working again just as I pulled into a car parts store, thinking it might be a fuse.) I ordered the switch from ECS tuning, so it will probably be here in moments! They're so fast!
Thanks for this detailed information!
  #23 (permalink)
Old 03-23-2008, 05:42 AM
Lnzbug's Avatar
MINI & NB FOR LIFE!
Arlington Heights, IL, USA
You could also just look at any of my first posts on a page. It's in my signature because so many people were having that same problem.
  #24 (permalink)
Old 03-25-2008, 09:06 PM
ohclementine's Avatar
Denver, CO, USA
Car: 2002 Turbo
Thanks for posting this. I bought my Beetle at a Ford dealership and they usually have no clue about what to do when I take it there to be fixed (I have a Ford warranty ). I bought the part, showed them your how-to and they were able to install it for me!
  #25 (permalink)
Old 05-13-2008, 10:58 PM
Albuquerque, NM, USA
Car: 2003 GL TDI
A few clarifications regarding this ...
1. Photos show configuration for '98-'03 models--switch is different and in different location on '04-up models.
2. Photos show car without heated seats. If car has heated seats, pulling off the outer front panels is complicated by fact the heated seat switches are attached to wiring harness.
3. Bentley manual states that the switch can be simply removed outward without need to remove the panel at all. (See illustration.) Would need to pull off the blank and/or press adjacent switch to on and then pry switch out from the side according to the manual. I'd recommend caution using this method.
Kent Christensen
Albuquerque
'03 GL TDI, '07 GL320CDI, '06 E320CDI
  #26 (permalink)
Old 05-14-2008, 03:34 AM
Lnzbug's Avatar
MINI & NB FOR LIFE!
Actually, that's what I did. I didn't unscrew anything, I just popped it out.
  #27 (permalink)
Old 07-14-2008, 02:20 PM
What are the exact symptoms for the switch failure? I tried searching the forum, but this is the only post I could find. I just started experiencing signal problems and I'm thinking this is the problem. When using a turn signal I get 1 flash of the signal on the dash, then it stops. Outside signals do not work at all. Also flashers do not work.
Thanks
  #28 (permalink)
Old 07-14-2008, 02:50 PM
Lnzbug's Avatar
MINI & NB FOR LIFE!
Thanks
That sounds like the relay.If all your bulbs are working & seated properly then replace the relay.
  #29 (permalink)
Old 10-28-2008, 05:36 AM
I wanted to thank you for posting this.
You saved me around $500. The dealer already charged me $80 for a diagnostic, said the sockets were bad. They quoted me around $400-600 for labor and parts. I spent $35.00 and did it on my lunch break. Thank you, I can make safe turns now and I'm thrilled. You really made my day
  #30 (permalink)
Old 10-30-2008, 05:06 AM
j.loicx's Avatar
Turbie
Memphis, TN, USA
Car: 2002 turbo S
thank you so much!!! i've been sans blinkers for a couple of months because i was under the impression that it was gonna be super expensive to fix and i'm pretty broke!
  #31 (permalink)
Old 12-02-2008, 01:14 PM
qtbug03's Avatar
OK,
Car: 03 Turbo Vert~ lil miss sunshine
Thanks! But I have heated seats, mine's an 03 and it is different, got any ideas on how to change that?! Thanks!
  #32 (permalink)
Old 12-03-2008, 04:08 AM
Lnzbug's Avatar
MINI & NB FOR LIFE!
I have heated seats & it works pretty much the same way. I just popped out the middle part where the hazard switch actually is.
  #33 (permalink)
Old 01-28-2009, 10:53 PM
chris22104's Avatar
Do you have a part #? And is it a dealer item only?
Thanks!
  #34 (permalink)
Old 01-29-2009, 04:34 AM
Lnzbug's Avatar
MINI & NB FOR LIFE!
  #35 (permalink)
Old 02-01-2009, 07:54 PM
JttrBug's Avatar
Got gremlins????
Derby, KS, USA
Car: 2002 Silver Turbo S
The part itself should only be like $18-$20.
You can also just pull the hazard switch out from the front without taking any panels off, by grabbing the lip under the front of the switch and gently pulling it out making sure to hold onto the wire with it or else once you have disconnected the old switch the wire will pull back through and you will have to work to reach it. A hook tool might help with this as well, but once it's connected you can just puch the switch back in. I just replaced mine not too long ago and I have an 02 turbo S with heated seats.
  #36 (permalink)
Old 09-09-2009, 10:33 PM
Cranford, NJ,
Smile Wonderful Job!!
Thanks so much...the relay did the trick...your directions were fantastic!! Ordered from http://www.germanautoparts.com/
Delivery in one day under $30.
Thanks again!!
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
hazard/turn signal flasher kneeskrapr Questions, Issues, Concerns, or Problems with the New Beetle 6 12-05-2010 01:19 PM
Hazard Switch clicking dhickey Questions, Issues, Concerns, or Problems with the New Beetle 1 01-28-2006 08:19 PM
relay block? jazzcat 2.0 Liter Gas 1 01-12-2006 12:47 PM
WTB: short, thin RSi turn signals praject2501 Market Place Archives 0 12-16-2005 01:33 AM
Horn relay location? bigsnack 1.8 Liter Turbo 0 12-15-2005 09:44 PM
