| Technical How-To Step by step threads showing you how to perform various technical and performance related tasks. |
Now Attach the passenger side sway bar clamp to the pillow block. Do not do the driver side yet.
Once that bolt is started, then start the other three into the steering rack thru the sub frame and get it reattached.
You can then secure the sway bar clamp to the pillow block on the drivers side as the steering rack is now positioned just below it. If you reattach this clamp first, you will not be able to get the steering rack positioning pin back in its hole. |
Now tighten up all four steering rack bolts 13mm to spec as well as the sway bar clamps to the pillow block.
The next step is to further jack up the sub frane until you can start the two long sub frame bolts that go into the pillow blocks. These are the front two 21mm bolts. Use New bolts!! |
Once the new drop links are attached, screw in the sub frame bolts and watch that the steering rack top gasket (#8 in drawing) reseats correctly as the sub frame lifts back up.
These bolts go in at 70ft-lbs. That's it you are done. Put back the three plastic sound/dirt skirts and put your wheels back on and lower the car. Tighten the wheel lugs on the ground. Grab your fourth beer...this is a four beer job!!! Here is a final picture of your take off parts. 1. POS stock sway bar. 2. Two POS stock drop links. 3. Four subframe bolts - must replace with new. 4. Stock sway bar bushings. |
To discuss this How-To please visit the link below...
Front H&R 26mm Sway Bar Install - (How-To) -Discussion Thread<---click here |
| Currently Active Users Viewing This Thread: 2 (0 members and 2 guests) | |
| Front and Rear Euro Emblem Install - (How-To) Discussion | marvins_dad | Styling Modifications | 34 | 05-19-2010 04:00 PM |
| Front H&R 26mm Sway Bar Install - (How-To) - Discussion Thread | marvins_dad | Technical Modifications | 6 | 09-21-2007 05:30 PM |
| Front and Rear Euro Emblem Install - How-To | marvins_dad | Styling How-To's | 7 | 09-19-2005 05:44 PM |
| Caractere Front Grill Install - How-To | marvins_dad | Styling How-To's | 15 | 09-17-2005 01:17 AM |
