| Technical How-To Step by step threads showing you how to perform various technical and performance related tasks. |
How-To by tsuter
PLACEHOLDER - http://forums.newbeetle.org/showthre...threadid=54673 Front H&R 26mm Sway Bar Install - How to It's no wonder that the front sway bar update on New Beetles is not seen very often. The install can be a PITA as you must lower the subframe and disconnect the steering rack. But when you look at the flimsy 22mm front stock bar and the even flimsier stock drop links, you can see that an uprade to an H&R 26mm with VF Engineering solid drop links is a good idea. With this setup I would run an H&R 28mm rear sway bar... in fact I do!! ![]() Here are the steps... First, securely jack up the front of the car and place on wheel stands. I used the removed wheels as a secondary safety measure at the sides:
marvins_dad ~ antoineCheck out Marvin's Website!!! | Beetle Pic Thread | Personal Pic Thread | DFW New Beetle Club Forums | Farewell TJ - Missed! Last edited by marvins_dad; 09-16-2005 at 09:06 PM.. |
Here is a drawing of the steering rack. The four bolts go in the four corners of the casting--part number
#14. Notice the locator positioning pin on the drivers side front of part number 14 in the drawing. This is very important. SteeringRack |
You will then need to use your hydraulic jack to support the lower sub frame assembly as you will need to lower it 4-6 inches to gain access. It is bolted on by four monster stretch bolts that must be replaced
when you reinstall the sub frame.The front two go up thru the pillow block mounts on the frame. These are 21mm hex bolts and they are 70ft-lbs you will need a serious breaker bar to get them loose. |
Use the hydraulic jack now and slowly lower the sub frame 1-2 inches. Watch and you will see that the steering rack on top of it does probably not separate.
That is because on the drivers side above the pillow block is a the positioning pin in the steering rack and it is stuck/wedged below the sway bar. See my finger. Use a large screw driver to pry the steering rack loose. You do not want the steering rack to be pulled down as you lower the sub frame. |
The stock sway bar can now be removed by rolling the ends of the sway bar backwards over the drive axels
and then working it forward until it comes out. No pictures. Its loose. You'll figure it out. Set the clamps to the side as you will reuse them but not the bushings. Have your second beer now after the stock sway bar is off. Now you get to remove the upper bolts from the stock drop links to prep the new drop links. |
| Front and Rear Euro Emblem Install - (How-To) Discussion | marvins_dad | Styling Modifications | 34 | 05-19-2010 05:00 PM |
| Front H&R 26mm Sway Bar Install - (How-To) - Discussion Thread | marvins_dad | Technical Modifications | 6 | 09-21-2007 06:30 PM |
| Front and Rear Euro Emblem Install - How-To | marvins_dad | Styling How-To's | 7 | 09-19-2005 06:44 PM |
| Caractere Front Grill Install - How-To | marvins_dad | Styling How-To's | 15 | 09-17-2005 02:17 AM |
