Which Version of VAG-COM should i use? - NewBeetle.org Forums
Old 06-19-2006, 05:28 AM
mezonesxbox's Avatar
Beetle maniac
Newport Beach, CA, USA
Car: New Beetle 2000 GLS, Audi A6 2000
Default Which Version of VAG-COM should i use?
Anyone have an idea of which version to use. I have seen their web site, but its all very confusing with the different interphases.
My car is a NB 2.0 2000 and i have the USB to OBDII cable
HELP!!!
By the way anyone know if checking the Tranny Temp is a free feature or do i need to purchase the full version?
Thank you
Old 06-20-2006, 07:21 PM
WA, USA
Car: '00 NB GLS 1.8T and '01.5 Passat GLX V6
Yeah, the free version will give you trans temp, go into block 02, then select channel 04, that will display the temp. As for version, I'm guessing you have a 3rd party cable, and the majority of the newer ones work with the 409.1 version. Try this link http://www.ross-tech.net/vag-com/dow...ease4091us.exe for the USB 409.1 version. There is a test utility that you have to do the first time you run vag-com that will establish connectivity with your ECU. If this version doesn't work, try ver. 311.2.
Old 06-21-2006, 01:34 AM
NBTurboFreak's Avatar
20V GTRS
Car: 2001 Sliver Arrow GLX
The Ross-Tech USB version may not work as the actication code is part of their cable. I have the their latest Vag-com setup and it works like a charm.
MySpace -- Piczo Pics -- WoW
HVWC 2010 Public Relations
What's your "Ron Mexico" name?...Version 2.0 scarabY2k Quizzes 35 01-17-2010 07:59 PM
Is this 2.5 a version of the old Audi 5 cyl.? bockegg 2.5 Liter Gas 22 08-14-2006 03:02 AM
Some pics of Badness Version 2.0 Badness Photos: New Beetles 15 06-01-2006 09:18 PM
Urdu version of Norwegian anthem proposed. PhoenixRising Miscellaneous Hoo-Ha Archive 3 05-22-2006 06:20 PM
New Beetle GP 2006 (Mexican version) Pulgamovil The New Beetle Experience 11 10-10-2005 01:54 AM
