VW/Audi Key Login Reader - NewBeetle.org Forums
Old 08-04-2006, 09:30 PM
Duffy's Avatar
Duffy II
Jonesboro, AR, USA
Car: 2009 NBC Harvest Moon
Default VW/Audi Key Login Reader
This my be a way for some to read and program keys without the SKC! I don't know if it will work with both 4 and 7 digit SKC's. Just found this on the web so check it out. I also found a site where I have downloaded the VW/Audi key login program. Here's the site to go to: http://www.motarway.com/new%20en/login.htm. Go to the site and post your comments here. I have no knowledge about this product and if will work.
Tom
Old 08-06-2006, 03:37 AM
180 Degrees out of faze
Central Coast, CA,
Car: 98 TDI NB.
Looks like it should work. You can do the same thing using Vag-Com from Ross-tech. And, so much more.
VAG305 - VAG / OBDII / CAN Code Reader SilverSportNOLA Questions, Issues, Concerns, or Problems with the New Beetle 1 07-24-2006 03:40 AM
OBD II Code Reader on sale at Canadian Tire dalethompson The Canada Corner 0 05-03-2006 06:59 PM
Actron PocketScan Code Reader Bugster 1.9 Liter TDI 10 03-08-2006 03:03 PM
lost of spare ignition key and backup key faulty(no data found)...PLS help atomwhiz Questions, Issues, Concerns, or Problems with the New Beetle 1 12-11-2005 11:36 AM
lost of spare ignition key and master key faulty with no data found..help pls! atomwhiz Technical Modifications 1 12-11-2005 11:11 AM
