Headlight replacement - NewBeetle.org Forums
Old 08-26-2006, 06:41 PM
Default Headlight replacement
Hi,
Have low beam headlight out/drivers side. How easy is it to replace?
Have a 2000 NB. 2.0...
Thanks,
Dick
Old 08-27-2006, 09:21 AM
kcfoxie's Avatar
I'm not a girl. Sorry!
Durham, NC, USA
Car: 2003 New Beetle TDI
Hi Dick! The simple answer is: Open the hood, you'll see the housing for the headlight assembly. There should be a lever, push the button next to it in and pull it down. This unlocks the headlight assembly, it should move forward a little bit once released. I suggest using a suction cup or a plunger to grab the front lense and start pulling. If you don't have either of those, pry CAREFULLY along the edges, the whole thing pulls right out. From there disconnect the wiring harness connector and open the plastic cover on the back. The low beam bulb is the *top* bulb; unhook it's connector, pull the old out, unplug, plug in new one, drop into hole and latch down. Put the cover back on, plug the wiring harness connector back in, and align the pegs on the unit to the tracks inside the fender/headlight assembly. Push it in, then pull the latch up to lock it.
It can be a 2 hour ordeal the first time. It's a very unique design, i'll put it that way. These cars are NOT $5/bulb headlight replacements at Pep Boys ....
Reference Tom's excellent write-up with photos if mine aren't clear enough: http://www.newbeetle.org/forums/showthread.php?t=171 (in the How-To section, under technical).
Old 08-27-2006, 04:59 PM
Thanks Tom...will give it a shot this afternoon, and let you know how many four letter words I used.
Old 08-27-2006, 11:24 PM
Replaced the bulb successfully. Took some time, but got it done. Hard getting the headlight out, and also hard getting the lever to lock again after replacing the bulb (was on drivers side).
Thanks for your help....
Old 08-28-2006, 12:12 AM
r0nd3L's Avatar
Me Gusta!
Lombard, IL, USA
Car: 2003 Turbo S
If I were you I would remove the latch (3 bolts) and clean/lube everything. After that, headlights go in and out without a problem.
2003 VW Turbo S Platinum Grey
Old 08-28-2006, 01:47 AM
mgwerks's Avatar
Cherchez la coeur...
Bandera, Republic of Texas,
Car: Oso - a black 99 GLS TDI
And be careful what you lube it with - I'd suggest silicone spray or graphite - anything else will just attract dirt.
Your fog lights are on,
It isn't foggy today -
You are a doofus.
Old 09-03-2006, 11:05 PM
treblatsirc's Avatar
Ciarog
Tacoma, WA, USA
Car: Black 1999 GLS
I just did my passenger bulb and had to remove the slider unit that cinches the bulb in, it was full of grit but now that I've done one I must say it's not so bad... not so simple either but not so bad
Old 09-03-2006, 11:25 PM
73standard's Avatar
Jacksonville, FL, USA
Car: '99 NB/ '73 Standard
Bulb replacement in a bug is one of the biggest pains in the ass I've had to deal with in a car. We've had two and both have liked to fight us every step of the way. I think I cursed every single German engineer that designed that system.
Old 06-09-2008, 03:28 PM
Just found this thread and need to replace the bulb on my passenger side 2001 Bug....
Does anyone have pics since that previous thread posted has dead pics
rick
04 GPW/Onyx Acura NSX
04 White BMW m3 cabrio
05 Rio Yellow S2000 CTSC *sold
08 Suzuki Hayabusa
08 White Lexus IS-F
Old 02-20-2011, 03:13 PM
Fuego's Avatar
pictures are dead again...
Headlight gasket replacement? cjmandrake Questions, Issues, Concerns, or Problems with the New Beetle 18 04-10-2011 06:44 PM
Windshield Replacement Bob The Canada Corner 14 08-20-2010 12:14 AM
Horn Replacement fohveh Questions, Issues, Concerns, or Problems with the New Beetle 6 12-27-2006 06:06 PM
WTB: replacement clasp or replacement armrest lid FineExampl Market Place Archives 2 08-11-2006 04:00 AM
Battery Replacement - How-To marvins_dad Technical How-To 8 10-07-2005 03:57 AM
