Euro switch mods - adding additional lights - NewBeetle.org Forums
Old 09-11-2006, 05:37 AM
vgmnstr's Avatar
You remember me FOREVER!!
West Palm Beach, FL,
Car: 2001 Reflex Silver GLS TDi "Buckie"
Default Euro switch mods - adding additional lights
has anyone had any luck in adding an additional set of lights for the second pull on the euro switch? I'm not interested specifically in adding a set of rear fog lights, but I'm searching for info in general in how to wire something additional into that space. Would I have to replace the plug or splice into any wiring in there. I haven't replaced my switch with the euro yet, but I should start looking up the info for the extra setting.
Old 09-11-2006, 05:43 AM
Toad's Avatar
big poster turned lurker.
Mableton, GA, USA
you could easily add a lead to the rear fog pin to a relay for another set of fogs.
Old 09-11-2006, 05:57 AM
vgmnstr's Avatar
What if I just wanted to add a generic or aftermarket set of lights? Do I have to add wiring to a specific pin on the harness to tie into it?
Old 09-11-2006, 02:10 PM
Toad's Avatar
Mableton, GA, USA
yup, you can tie it into the rear fog light pin on the euroswitch. I'd run the fogs on a relay though. The rear fog is only like a 5w bulb i think. So I wouldnt run anything more without a relay.
Old 09-13-2006, 04:43 AM
vgmnstr's Avatar
Any idea which pin it is? I just got myself a Bently manual, would it be listed in there somewhere?
Old 09-13-2006, 05:51 AM
Toad's Avatar
Mableton, GA, USA
I dont rember off hand, i think TFL. It's on the top most rightside (closest to the steering wheel) right when you pull it out.
Old 09-13-2006, 04:22 PM
paultakeda's Avatar
Bourgeoisie
Venice, CA, USA
Car: 2001.5 NB GLX AWV 02J LG5T 08H/ZD + mods
TFL is the DRL pin. The pin labeled NSL is for the second pull on the Euro switch, which is normally used for the rear fogs but you can use it for anything, really.
Old 09-14-2006, 05:56 AM
Toad's Avatar
Mableton, GA, USA
Hey, at least i got the L right. hehe.
Old 09-17-2006, 05:41 AM
vgmnstr's Avatar
Are the pins labeled on the switch? The bently manual only shows circuits for the 1 pull american fog light switch. And when I find it, would I just pass the signal through a relay to ground in order to use it? Or would I have to wire it up a different way?
Old 09-17-2006, 06:45 AM
Toad's Avatar
Mableton, GA, USA
Yup. Pull the swithc out and plug it out, they are stamped right under hte pins.
Old 09-17-2006, 04:08 PM
vgmnstr's Avatar
I'm looking at the old switch now and I see them. Thanks.
Old 09-19-2006, 04:24 AM
vgmnstr's Avatar
Ok, here's another question. Which plug/wire goes out for the 1st pull fog light setting?
Adding OEM Fog Lights mel72349 Technical Modifications 0 08-02-2006 06:34 PM
Adding OEM Fog Lights mel72349 Questions, Issues, Concerns, or Problems with the New Beetle 0 08-02-2006 03:23 AM
will this euro switch work with my 98 lady bug 2.0 Liter Gas 1 06-24-2006 04:27 AM
Adding the Turbos S City Lights to a Non-S Car heyou Technical Modifications 5 04-28-2006 04:29 PM
Euro Switch MotorsportsAuthority Market Place Archives 12 12-15-2005 01:47 AM
