Voltage Stabilizer and Gound wiring - NewBeetle.org Forums
Old 09-12-2006, 03:17 AM
richmond, B.C, Canada
Car: 2001 beetle 2.0
Default Voltage Stabilizer and Gound wiring
Have anyone use them or know how they preform?
i saw these kinda stuff on eaby and said add more power and so.
Old 09-13-2006, 02:31 PM
El Subcomandante's Avatar
El Subcomandante
Veracruz Mexico, Mexico
Car: AEG engine 99 model Automatic
I have used the grounding cables and it works.. Audio sounds better, and you feel the engine a little bit more stable..
I recomend to install the Hiper grounging system.
El Sub...
El Sub..
If you want to learn mechanics, own a VW...
Old 09-14-2006, 12:20 AM
nobody ever use the stabilizer????????
Old 09-14-2006, 03:33 AM
vdubbugman53's Avatar
Arvada, CO, USA
where can we get that ground kit
Old 09-14-2006, 09:54 PM
go to eaby there lots of them around 10 to 30 $$$$$$$$$$$$
Old 09-14-2006, 11:10 PM
Arvada, CO, USA
where did you fint the stablizer i found the ground kits but not the stabalizer
help with headlight wiring BigFatDuck Questions, Issues, Concerns, or Problems with the New Beetle 0 06-30-2006 11:08 PM
Wiring Guru help needed. Toad Questions, Issues, Concerns, or Problems with the New Beetle 0 04-27-2006 05:59 PM
Wiring Willard 1.9 Liter TDI 2 12-15-2005 02:32 AM
Wiring Question TechnoKäfer Car Audio 3 11-22-2005 01:14 AM
Lucas Heavy Duty Oil Stabilizer? Crazy_MoFo 2.0 Liter Gas 7 10-28-2005 11:16 PM
