Coil pack installation - NewBeetle.org Forums
Old 10-23-2006, 11:09 PM
Bainbridge, IN, USA
Car: 2000 Techno Blue 1.8T GLX
Default Coil pack installation
May be a stupid question, but is there anything more involved in coil pack replacement than taking the old ones off/out, putting in new ones, hooking up wires/etc? I need at least one and figured I'd go ahead and do all four.
Also, are these the right ones (from ECS)?
OEM Coil Pack-Latest "E" Version-Priced Each ES#1551
- only fits up to VIN #Y499000 learn more
for my 2000 1.8t glx? Thanks!
Old 10-24-2006, 02:52 AM
SilverSportNOLA's Avatar
Faster Than Katrina
Formerly New Orleans, LA, USA
Car: 01 Sport
That's about all that is involved. If you are asking then you haven't changed your own plugs. Note ... be careful pulling the wires out, I broke the plug on my #4 when that coilpack failed .. my first time removing them. You will also have to remove the stuff that is over the #1 and 2 cylinders to remove those. The packs have rubber seals ... so they tend to stick from suction .. just pull them up firmly.
Old 10-24-2006, 03:20 AM
lojasmo's Avatar
Goon Squad Atheist
South of Angle Township, MN, USA
Car: 1995 Subaru BK
Yeah, it's that easy. Replace the spark plugs while you're at it....and all the vaccuum hose on top of that mess.
If the people cannot trust their government to do the job for which it exists - to protect them and to promote their common welfare - all else is lost.
-Barack Obama
Old 10-24-2006, 05:16 PM
Bainbridge, IN, USA
I am.
Coil packs... Katiebug Questions, Issues, Concerns, or Problems with the New Beetle 12 10-21-2006 03:07 AM
Coil packs and hoses - what do I have? Audiophil 1.8 Liter Turbo 7 10-12-2006 12:08 AM
Coil Packs for AWV Crystalgolem 1.8 Liter Turbo 1 10-06-2006 04:08 PM
Coil Pack Recall???? *damsel In Distress* midgy33 1.8 Liter Turbo 12 07-30-2006 06:06 AM
