What fuse controls the - NewBeetle.org Forums
Old 10-26-2006, 03:59 PM
Default What fuse controls the
When locking the door with the key. It makes the lock sound and makes the horn beep.. Is their a fuse that can stop this from doing this.
Also is their their a fuse that will cut off the security sys. I lost the remote and now have a key.. The alarm went off when a lady got in put key in with door open.
I finally figure out. Close the door put key in lock un lock it went off.
Old 10-30-2006, 03:15 AM
Francia's Avatar
Driver Found
Montreal, QC, Canada
When I got my Beetle about a two months ago (it's a 2000) the horn wouldn't beep and I wanted it to. My friend is a VW mechanic and activated it using his computer and OBDII. It's a very quick procedure, a few minutes. You can have it deactivated the same way, but I suppose if you don't personally know a VW mechanic than you might have to go to a dealer. There are no fuses to deactivate the horn only.
As for the security sys, I'm not sure that would be a good idea. I believe the security system might work in conjunction with your coded ignition key. I would verify that before removing fuses for the security system as otherwise your car wouldn't start.
Hope this helps!
Do Your AC/Heat/Fan HVAC Controls Light Up? paix247 Questions, Issues, Concerns, or Problems with the New Beetle 40 11-16-2011 10:52 PM
1.8 turbo 2000 Beetle Window and Lock Controls. khhamil Questions, Issues, Concerns, or Problems with the New Beetle 0 09-24-2006 09:59 PM
XDVD8182 iPod Controls kaiimac Car Audio 3 09-06-2006 12:31 PM
new idea? stereo controls on the steering wheel 58ragtop Styling Modifications 13 04-22-2006 11:34 AM
OEM Head unit tape player, with CD Changer controls carchrism5 Market Place Archives 8 04-17-2006 11:50 PM
