99% of the install was an absolute breeeeez as in under 30 minutes. The last 1% was a total bitch and took us two days of work totaling some 10+ hours.
What was it? Trying to get the lowest vacuum line onto the TIP. They were at odd angles and no room to get any tools in there or more than one finger at a time. ACK!!!!!! |
Here is a link to my how to: http://www.eclubvw.com/forums/showth...ighlight=samco I created one on the old Forum ... but it is not over here and I have not come across it there paging through the 1.8T forum, where I think it is ... I can't search for it ... Tom .... Maybe you can move it for me ... Hurricane Katrina kept me away during the transition so my How-Toos did not get over here. |
if u dont bust knuckles ur a poon and should prolly be stabbed 7 or 8 time... u need battle wounds.... its a vw way of life
03 evo vIII 2.3 gt35rhta... 93 eagle talon awd gt42 91 talon gt35r dd 08 cbr1000rr 1000hp club!!! |
Ya I installed the SAMCO pipe today alone...Dammmmmm it went so fast... But what helped is taking off the plastic cowl vent and the steel shroud at the firewall.had it all together in about an hour, untill the Dammmm SAMCO hose clamp to the copressor housing started walking.And if I got it to stay in place,the clamp would walk...finally made a bar that I could pry with to hold clamp & hose in place...
Thought I was in the clear, untill the vaccum hose wouldn't go over the SAMCO nipple fitting. spent about an hour on that and decided to piece in a short brass fitting & hose...My knuckles aren't bad but my shoulder's are Numb... I only had ramps to do the JOB. All in All It's a GRAVY JOB...Now I need to get rid of that pancake pipe going to inercooler... UPsolute called, the software is in. but can't get to him till Saturday..."Directions were apprecieted" Last edited by speedsk8er; 11-15-2006 at 03:16 AM.. |
Great deal .... soooooooooo ... did you drive it yet. Does it feel different ... sound different? I installed mine before Chipping also.
Glad you were able to get that hose on ... if I ever do it again I will probably remove it from the other end and attach it to the nipple first and then on the other end when everything else is in. |
Don't recall how close but I am pretty sure I would not have tightened it down without having it all on the lip of the turbo inlet. And if you have a K04 on there ...there may be a difference.
The one I was worried about was the hose on that nipple ... had to use the OEM clamp ... but due to the increased size of the nipple ... it was a tight squeeze getting it over the nipple and hose ... thats why we had to slide it on the hose .. keep it open while trying to get the end of the hose over the nipple. It was a real PIA, I thought Samco would have resized that nipple to match the OEM pipe by now, like we really need it bigger for more vacuum with the higher flow going through there, even without the chip. Did you use the Samco Clamps? |
Only used the SAMCO clamps on the two large ends... But just got back from a 10 mile ride. Dammmmmm the Turbo really has a high pitch wind. And the deverter valve from stratmosphere really peshhhhooooo in between gears LOWDER. Great performance, hits boost QUICK... I love it.. Just checked on exhaust. Don't know if I'm going to run a 2.5 or 3" downpipe yet? and I might try it without a muffler with high
flow cat and all 2.5".
h----------l no... But this KO4 has a real high pitch spoolup sound. I'd almost listen to the Turbo more than the stereo...
one of my favorite mods, but i couldnt pay it to fit easily, and it took me 3 hours
| turbo inlet pipe | bobbittle | Technical Modifications | 12 | 05-03-2007 04:33 AM |
| WTB: aftermarket turbo inlet pipe | ninsei | Market Place Archives | 2 | 02-28-2006 03:49 PM |
| FS: KO3 turbo + inlet pipe. | slugII | Market Place Archives | 1 | 12-14-2005 02:08 PM |
| FS: NEUSPEED 1.8T Turbo Inlet Pipe | Zookie | Market Place Archives | 3 | 10-05-2005 08:36 PM |
