How to Remove rear panel 98 Beetle - NewBeetle.org Forums
Old 12-30-2006, 05:39 PM
Default How to Remove rear panel 98 Beetle
I want to change the speakers in the rear panels of my 98 Beetle and want to know how to get that panel off.Is it all one peice from beside the seat to the window.I can't tell if it lifts up or if you pull it out.I just don't want to bust any thing.The speaker doesn't work that's why I need to get it off so I thought while it's off I might as well update the speakers.Any insight would be great.
Thanks
Old 12-30-2006, 10:20 PM
rawr's Avatar
Bender
Tromso, Norway
Car: Silver Arrow Neü Beetle Tdi
Thanks
Did this some months ago..
I would start by prying the black part out of the door gasket. there are some pops on the B-pillar below the driver seat belt.
There are also two pops at the other end of the rear panel, behind the back-part of the rear seat. Do the B-pillar pops, then the two in the back. Now all you have to do is to lift the panel upwards. Be careful, it is kinda easy to break the top part(painted) of the back panel. It sits on a metal frame with approx 4-5 metal clips.
Remember to remove the seat part of the back seat and lay the back forward.
Found the how-to I used..
http://newbeetle.org/forums/attachme...8&d=1129089941
More here:
Technical Bulletins - Audio
Good luck
(\o/) 83 Stylingjunkie 1.91m
(o) 99 VW Beetle 1.9Tdi Highline
(x) 97 Audi A3 1.6
(x) 93 BMW 318i
Old 03-30-2011, 03:40 PM
TigerBug's Avatar
Central, LA, USA
Car: supa dupa yella bug
Most helpful, always pays to read thru old threads!!
1995 & 2005 Mustang GTs - 1996 Sierra Z-71 - 1999 New Beetle
Old 03-31-2011, 06:45 AM
Thanks Rawr! PDF is now saved, the rear panels are one of the few things that I've never removed from my car.
How do I remove the center dash panel? FineExampl Styling Modifications 5 08-19-2009 08:10 PM
How To Remove Rear Door Panels? yellow99 Styling Modifications 5 09-12-2006 01:31 PM
Remove Door Panel s_santiago Styling Modifications 2 01-16-2006 07:02 PM
Having window problems - how do I remove door panel? HadToHaveAY2Kbug Questions, Issues, Concerns, or Problems with the New Beetle 7 01-15-2006 10:48 PM
