No master KEY to program remote - NewBeetle.org Forums
Old 01-03-2007, 11:43 PM
Default No master KEY to program remote
First I'd like to thank everyone that sent me on info I asked for on here.So some of that help had to do with programing my remote.Well I went out to try it but it seems I don't have a master key because I can't lock or unlock the doors with the key I have.So how do I program the remote now with out the master key.Is there something special about the key.It must be a little different for the doors as it works fine in the ignition.Is it something else I will need the dealer to do now that I can't.
Old 01-04-2007, 02:04 AM
kcfoxie's Avatar
I'm not a girl. Sorry!
Durham, NC, USA
Car: 2003 New Beetle TDI
sounds like you've got a valet key that will unlock the driver door, but not the trunk, and start the car. does it or does it not unlock/lock the glove box?
Old 01-04-2007, 02:27 AM
You are correct I'm undergoing this scenario as we speak. I just got my master key in from keylessride.com and took it to the dealer to get it cut. Unfortunately, my valet key was a little worn at the tip, so they weren't able to get and accurate cut. So I had them order me another valet key and from that one they will be able to cut my master key and then I can program it.
But yep that is the valet key KCFoxie.
Old 01-05-2007, 11:58 PM
Default New key a dud
It will unlock the glovebox the trunk and will start the car. It will not open the drivers or passenger doors.Even the new key I just bought for $90 will not open the doors.
Program a KEY 98 Beetle bug_n_67 Technical Modifications 1 12-30-2006 08:34 PM
I only have a valet key - how do I get a master? tmoth Questions, Issues, Concerns, or Problems with the New Beetle 4 09-04-2006 05:58 PM
Need a new master key. nagal Questions, Issues, Concerns, or Problems with the New Beetle 3 05-17-2006 01:37 PM
Remote Control Key Barnum 2.0 Liter Gas 4 12-13-2005 04:28 AM
lost of spare ignition key and master key faulty with no data found..help pls! atomwhiz Technical Modifications 1 12-11-2005 11:11 AM
