HELP with the Old Style Horn - NewBeetle.org Forums
Old 01-19-2007, 01:00 AM
GalinHdz's Avatar
GalinHdz
Brunswick, GA, USA
Car: 3 Beetle TDI's 2000, 2000, 2006
Unhappy HELP with the Old Style Horn
I installed an old style (Beep-Beep) horn on my 2006 NB. It works off and on. After a few days it starts working again then stops. Can anybody help?
Old 01-19-2007, 04:49 AM
Beetlemania's Avatar
crank it up, suckers!
Broken Arrow, OK, USA
Car: 1999 Silver Aero GL
I'd say it has to either be a problem with the wire or the switch. Let's hope it's the wire!
Have you checked all the connections again on the new horn?
I'm J-Dawg, flyin' down the road in Paul McCARtney, the only Beetle in wings!
Mi Bacca es Chewbacca!
I'm one of those people. Whatever that means.
Old 01-24-2007, 04:53 AM
CoriBug's Avatar
over 120k miles in 7.5yrs
Fort Collins, CO, USA
I just received mine from TVA and I'm taking it to the dealer to install.....(40 degrees outside no thanks!). I don't think they've installed an old beetle horn yet. Is there any rewiring required?
Cori
Old 01-24-2007, 05:34 AM
I just spliced into the factory wiring. The old Bug horn uses different connectors.
Old 01-26-2007, 02:09 AM
GalinHdz's Avatar
GalinHdz
Brunswick, GA, USA
Cool Number of Horn's
I replaced the two original horns with only one old style (Beep-Beep) horn. Did you replace the two original horns with one or two old style horns?
Old 01-26-2007, 05:18 AM
There are 2 horns in front of the left front wheel well. I spliced into the wiring of the lower horn, unplugging the original and plugging in the Old Beetle horn. I left the upper horn plugged in. So mine has an old/new sound.
Old 01-27-2007, 03:19 PM
dunno513's Avatar
dunno513
Alton, NH, USA
Car: 06 TDI NB w/DSG
Horn that the alarm uses is the same pitch as the original meep meep horns of the older bugs. I thought the true original horns were 6volt? They would require a bit more than simply splicing on new connectors.
Old 01-27-2007, 04:56 PM
Wheaton, IL,
Car: 04 TDI PD
The replacement Hella (old style) Beetle horn is 12V.
Old 01-28-2007, 12:39 AM
CoriBug's Avatar
I took my horn from TVA to the dealer so they could look at it and they said the connectors are different but the install should take 30 minutes at most. So Daisy will have a new voice this Friday!! YAY!
Cori
Old 02-07-2007, 02:41 AM
CoriBug's Avatar
Daisy has her new(old) horn in now!! The dealer gave me the 2 horns they took out - they are connected together. So does this mean the old style horn is the only one in there? I guess I could press the panic button and listen! The 'beep' when I lock it sounds like before but it's such a short beep it's hard to tell. The old style horn sounds a lot louder! I drove over to my dealer's house so he and his kids could hear it - he likes the idea so much he might install old style horns in the loaners.
Cori
Old 03-23-2007, 05:51 PM
Atomic_Knight's Avatar
Autobots! Roll out!
Camas, WA, USA
Car: 2001 New Beetle GL 2.0 ltr
How much did it cost for that instalation? I so wanna get Herbie that old style voice. It's like people expect it...
Old 03-24-2007, 05:34 AM
CoriBug's Avatar
It was around $45. My dealer did order and install some old style horns for his loaners, but I don't know which beetles.
Cori
Horn hdtv 1.8 Liter Turbo 15 01-29-2010 04:00 AM
Installing Old Style Horn Big Paws Styling Modifications 17 11-14-2009 11:57 PM
A little help with old style horn CoriBug Technical Modifications 5 01-15-2007 11:45 PM
Horn! Mister Styling Modifications 5 07-27-2006 01:09 PM
Horn Location. dvious Technical Modifications 18 05-04-2006 06:55 AM
