How do you remove the gauge face? - NewBeetle.org Forums
Old 02-24-2007, 07:28 PM
CA, USA
Car: Black NB 2002 GL
Question How do you remove the gauge face?
I'm trying to figure out how to remove the gauge face so I can replace it with another, but when I try I feel like I'm going to break something. Any help?
Old 02-24-2007, 08:58 PM
Sukhoidave's Avatar
4-Point Roll
Ravenna, OH, USA
Car: "Wink" my 2000 1.8Turbo GLX
It's an intimidating job! It's easy to get into the cluster, you probably know how to remove the trim ring and get the clear plastic off, that's easy. From there you will need to get the whole instrument cluster out. You may as well start with removing the needles. The center caps lift up at an angle then slide off the needles. Pull the needles straight up off their axles.
There are several connectors in the back of the instrument cluster that can be tricky to disconnect because its hard to get your fingers in there. They have sort of locking levers that you flip the opposite way to release. When you have the whole cluster out I believe there are some screws holding it together. If you open it up you are going to ruin a seal that will tell a service center that you have done so and have thereby voided any warranty that might cover any problems with the cluster, so now you proceed at your own risk. When you open up the cluster small parts are likely to fall out. They are probably little plastic spacers. Work very carefully to try to keep them in place.
When you get it apart you can push the gauge face from the rear to release the sticky glue holding it on the cluster. Push in several spots so it doesn't bend too much.
You put it all back together in the opposite order. It's more intimidating than difficult. * I used a solvent to get the glue off mine so that now I can just remove the needles and pull it off when I want to change mine.
Good luck!
Nowhere near fast enough.
Arbeit macht nichts
check out my car
Old 02-26-2007, 02:35 PM
marvins_dad's Avatar
I BELIEVE!
Dallas, TX, USA
Car: 2002 DIYCGCC TDI
Here's a How-To I did years ago, hope it helps...
http://www.dehon.org/antoine/Marvin-Speedo0.htm
marvins_dad ~ antoine
Old 02-26-2007, 03:28 PM
vdubbugman53's Avatar
Arvada, CO, USA
you disconnect the gauge cluster= hello AIR BAG LIGHT
Old 02-26-2007, 08:14 PM
jpdeuce's Avatar
Diesel Inside
Frisco, TX, USA
Car: 06 Jetta TDI
I did a How to for when I swapped the LEDs on my gauge cluster as well...but you will have to search a bit for it.
Old 02-26-2007, 08:54 PM
I BELIEVE!
Dallas, TX, USA
I think I stated in my How-To the following...
"DO NOT turn the key with the cluster out"
You will only get an Airbag light if you insert and turn the key while it is out. Best thing is to take it out of the ignition, or better yet, leave the keys inside so you don't accidently insert and turn.
I've done tons of these and never had a problem with the Airbag.
Old 02-26-2007, 09:14 PM
Billsbug's Avatar
Get in.Buckle Up.Hang on.
USA
Since we're on the subject, do u just pull on the plastic surrounds to get them off? I want to get mine painted, thx.
wolfsbürgwe.:Rks
Originally Posted by gilligan
Old 02-26-2007, 09:22 PM
I BELIEVE!
Dallas, TX, USA
Yeah.
Here is another How-To that BugMod did and we are now hosting...
http://newbeetle.org/forums/technical-how/856-guage-face-swap-how.html
Guage Face Swap - How-To marvins_dad Technical How-To 7 07-10-2007 01:50 PM
Custom Guage Face . . . . EvilinaDM101 Styling Modifications 10 08-18-2006 04:40 AM
pic of new gauge face detailstation Photos: New Beetles 10 07-05-2006 06:19 AM
Face it, everyone is doing it. My Lemming Quiz. licibug Quizzes 5 01-21-2006 05:19 AM
need help with installing gauge face!!! pipsqueak489 Styling Modifications 14 10-13-2005 07:13 PM
