P0118 code question - NewBeetle.org Forums
Old 03-18-2007, 10:12 PM
Curtis's Avatar
Seattle, Wa
Sammamish, WA, USA
Car: 1999 Gls
Default P0118 code question
I was driving today and the temp light started to blink red. I got home and hooked up my scan tool to the car and got P0118 code and all my coolant was drained. I had just put coolant in the car this morning. I read the code def. "Engine Coolant Temp Circuit High Input". Does anyone know what this means and how to fix the problem.
Old 03-22-2007, 05:34 PM
enoRegistered Member eno is offline
Houston,
Car: 02 GLS auto 2.0
When i had p0118code i replaced coolant temperature sensor to the 'green top'. I did not have a coolant leakage though.
Old 08-09-2011, 10:53 PM
Hi there,
I've done the same thing as you did, I replaced the temperature sensor to a green one, but the check engine light was still there. Did you do something else apart from just changing it?
Thanks so much,
Vincent
Old 08-09-2011, 11:30 PM
You'll have to clear the codes. The CEL won't go out on its own right away.
HELP! Code P0118 LilMolly 1.8 Liter Turbo 26 02-02-2007 08:26 PM
pcv valve question and oil question a_magoo 1.8 Liter Turbo 3 10-07-2006 01:31 AM
Help with CEL Code P0118 and P1296 eno 2.0 Liter Gas 1 07-31-2006 04:04 AM
p 0411 code question and coolant leak question.... bobbittle 1.8 Liter Turbo 5 06-12-2006 02:47 PM
CEL Light - P0118 and P1296 fulltiltredhead Questions, Issues, Concerns, or Problems with the New Beetle 2 05-14-2006 05:51 AM
