Hello,
I am new beetle owner. I just purchased a used '99 2.0L Beetle and noticed that when I turn on the vehicle, the "check engine light" does not come on. Needless to say, I plug my OBD2 scanner out of curiosity and got 4 different codes and no "check engine light". The codes were the following: P0117 P0140 P0301 P0341 My question is, can the "CEL" be disable and if so, how? I don't think the light just burned out, it's possible but just unlikely. I believe it was disabled or the bulb taken out on purpose. Can anyone help? Thanks, Alex |
Thanks for the replies,
Well, out of all of these codes, the only one I believe is the camshaft position one. The vehicle runs fine. In the morning, the blue temp light comes on and when the car gets warm it goes away. All the other light in the dash do work. I believe that if the car has a misfire you can hear the misfire at the exhaust. Correct me if I am wrong. The vehicle idles perfect. The only thing is that it has a light knock in the engine. I just filled it with higher octane fuel to see if it is that. Any othe other ideas as to why the "CEL" does not work? BTW, How do you test the Gauge Panel? |
There are a few temp sensors. Look at the one we all have replaced (not sure the exact location on the 2.0), if it is black, it is probably a problem, if green it has been replaced and the code was not cleared ... the ECU will keep codes stored in it even when all is operational again and the light goes out. The misfire, that may have happened once or twice so light wouldn't stay on. The O2 would surely keep the light on, unless the wiring harness was broken and repaired and again the code not cleared. So that leaves you with the CSPS ... hard to say. I can tell you how to surely make the light come on, just unplug the MAF and start the car up ... the light should come on.
I think on the 2.0 it is near where it is on the 1.8T ... it is in the space over the tranny between the engine and battery/airbox. There are a few there .... but the one you are looking for has 4 pin connectors on it when you take the wire harness off of it. Follow the hose from the top of the radiator that goes into the back of the engine ... it is along that hose.
| E-codes | JetPuf | Technical Modifications | 5 | 03-07-2007 05:47 PM |
| CEL codes-Help! | zakattack95 | 2.0 Liter Gas | 7 | 02-25-2007 04:58 AM |
| Misfire Codes!!! | pcb122 | Questions, Issues, Concerns, or Problems with the New Beetle | 8 | 01-31-2007 02:17 AM |
| need help with codes | bobaganoosh | 1.8 Liter Turbo | 6 | 12-30-2006 04:50 AM |
| e-codes | tjd | Technical Modifications | 0 | 01-20-2006 10:30 PM |
