ignition switch - NewBeetle.org Forums
Old 05-27-2007, 06:08 PM
chiRegistered Member chi is offline
Default ignition switch
I replaced the ignition switch in my 98 beetle it's a auto and a gaser, I didn't replace the cylinder just the electrical part of the switch, anyone know if you have to reprogram anything when you do this? It does nothing now when I turn the key on no lights on the cluster nothing, when I put the old one back in I have lights and it starts up(when it works), I am thinking I just have a bad new switch?
Thanks for your help
Old 05-28-2007, 01:05 AM
SilverSportNOLA's Avatar
Faster Than Katrina
Formerly New Orleans, LA, USA
Car: 01 Sport
I don't think the 98's had an imobilizer ... it may just be a bad switch. Hopefully someone with more experience will reply.
Old 05-28-2007, 02:41 AM
Ive run into this before. I have done my ignition switch twice now, the 2nd time needing the pigtail as well!
The 2nd time around though, I ended up getting 2 bad switches out of the box. One would work the ignition, but no start. Other way around on the other switch. Does the vehicle do anything with the new switch??
Ignition Switch Replaced-Now Won't Start jeff2761 2.0 Liter Gas 4 08-04-2007 10:03 PM
98 NewBee TDi Ignition Switch Issue UFO_TDi Technical Modifications 1 01-31-2007 11:55 PM
Ignition switch replacement on 00NB cangi710 2.0 Liter Gas 2 12-10-2006 06:43 PM
Ignition Switch problem - Turbo S turbojdub Questions, Issues, Concerns, or Problems with the New Beetle 1 06-17-2006 12:31 AM
ignition switch relay ? C89ZX7R Questions, Issues, Concerns, or Problems with the New Beetle 1 12-29-2005 05:58 AM
