vag com - NewBeetle.org Forums
Old 06-18-2007, 03:20 AM
mulligania's Avatar
vw uber alles
Boston, MA,
Car: 2001 1.8 AWV
Default vag com
so what do I need to get to interface with the ECU? I have a laptop. Do I get the Vag software from ross-tech? And what cable do I need? I want to keep this cheap-under 100$. I have a 2001 1.8 Any advice. Is it worth getting. I am sick of the CEL going off.
Old 06-18-2007, 05:54 AM
vdubbugman53's Avatar
Arvada, CO, USA
you will never get one under 100...you lookin at at least 300 and they are well worht it you use it like 5 times and it is paid for
Old 06-18-2007, 12:06 PM
NYBugman's Avatar
MkV Pilot
Brooklyn, NY,
Car: 08 CW GTI Pkg1 DSG
You can get a cheap vag cable from ecstuning.com and use and old version of vagcom available on ross-tech's website. However, the old versions are basic when compared to the new versions.
Plus, you will get NO tech support from ross-tech if you use a 3rd party cable. I ended up just biting the bullet and getting mine through ross-tech. It is worth the money, period. Pony up the cash and do it right.
Old 06-18-2007, 05:23 PM
mulligania's Avatar
vw uber alles
Boston, MA,
Car: 2001 1.8 AWV
I suppose it is worth the tech support alone, thanks for the advice
Old 06-18-2007, 09:27 PM
Arvada, CO, USA
plus the software alone is 100 bucks
Old 06-20-2007, 12:31 PM
QQQ's Avatar
QQQRegistered Member QQQ is offline
Fairfax, VA, USA
Car: Y2K GLS TDI
I agree it's cheapest to just buy the product outright from www.ross-tech.com. However, I did buy a third party cable $15, software $99 and used it as is for awhile. I was able to check and clear codes as well as make a few adjustments. Luckily, www.ross-tech.com does offer upgrades which amounts to the difference in cost of the software and cable. In the end, I was out $15 going this route.
Old 06-20-2007, 03:58 PM
sb_beetle's Avatar
CA, USA
Car: 2004 NBC 1.8T
Default What you need... go here
Just a laptop and then... go here for the specifics:Ross-Tech
It's well worth every penny.
SoCalnewbeetleclub
Vag-Com bugcrazy Miscellaneous Hoo-Ha Archive 4 12-02-2006 02:10 AM
Vag-com?? beetlegirlvw Questions, Issues, Concerns, or Problems with the New Beetle 3 11-30-2006 04:44 PM
vag com 2000GLX 1.8 Liter Turbo 2 09-01-2006 10:10 PM
Vag-com vw_beetle_gpx Technical Modifications 8 05-23-2006 05:22 PM
Vag Com tonhe Technical Modifications 8 03-02-2006 07:18 PM
