Changed headlight bulb, now dead battery. - NewBeetle.org Forums
Old 08-08-2007, 03:56 PM
Default Changed headlight bulb, now dead battery.
I have a 99 New Beetle, 2.0L Just changed out the low beam headlight bulb, now my battery goes dead. I did put in a fresh battery, same problem!! Any thoughts?
Old 08-08-2007, 03:59 PM
Lnzbug's Avatar
MINI & NB FOR LIFE!
Arlington Heights, IL, USA
Are the cables on tight? I can't see where this would cause your battery to drain
Old 08-08-2007, 04:02 PM
Cables all seem very tight. After putting in new battery. I had drove it about 60 miles to run errands; stopping and starting motor many times. After a bit the battery light came on and battery was dead.
Old 08-08-2007, 04:06 PM
Lnzbug's Avatar
MINI & NB FOR LIFE!
mmmmm Someone here might be able to help you. Give them some time to see this thread. I'm stumped.
Old 08-08-2007, 07:40 PM
SilverSportNOLA's Avatar
Faster Than Katrina
Formerly New Orleans, LA, USA
Car: 01 Sport
How quickly is the battery dying? Is it overnite, over a few hours ... minutes .... a week? Have you checked that no lights are left on. One of the reasons for the brake switch was to fix problems that would cause the brake lights to stay on all the time ... which would cause the battery to die .... and replacement by some trained VW monkeys would cause the problem.
Old 08-08-2007, 10:41 PM
Battery goes dead in hours. I do not see any lights (tail or head) still on. I am still stumped.
Old 08-09-2007, 03:20 AM
Faster Than Katrina
Car: 01 Sport
Check the luggage compartment light .... but I don't think it would kill it in hours. Is that in hours sitting or running. If running, I would get the alternator checked. I have always found that our batteries have very little to spare and run down over time, because the alternator doesn't charge them much with all the other electrical things to keep going. I put mine on a trickle charger every couple of months. Will probably do it soon since I have the car in the garage with the doors unlocked while doing some major maintenance .... probably be that way for a few weeks. Door unlocked will drain the battery faster than doors locked ... 4 weeks killed mine one time.
Headlight bulb replacement Buglover Technical Modifications 16 11-03-2006 02:20 PM
99 Battery going dead Please Help! C.Hotchkiss 2.0 Liter Gas 1 10-29-2006 05:17 PM
changed bulb but headlight still out okiebug Questions, Issues, Concerns, or Problems with the New Beetle 2 05-03-2006 10:28 AM
Dead battery or..? quiong Questions, Issues, Concerns, or Problems with the New Beetle 3 12-11-2005 04:15 AM
headlight bulb question zenewie Technical Modifications 5 09-29-2005 07:48 PM
