Reversing (Parking) Sensors (NOT factory fit) - NewBeetle.org Forums
Old 09-22-2007, 11:19 PM
Default Reversing (Parking) Sensors (NOT factory fit)
Has anyone installed 'in-bumper' rear parking sensors to their Beetle?
I've done this before to other cars so I know what to do - but want to know if it's easy to access the sensor wiring from behind the bumper and tap into the reverse wire OK?
Have posted this on the UK New Beetle Forum - loads of viewings but no one has replied.
My local VW dealer here in UK says it has to be an original factory fit - they won't fit them as aftermarket parts!
Thanks
Mark
Old 09-23-2007, 01:12 AM
macdave's Avatar
Olympia, WA, USA
Car: 01 1.9TDI Techno Blue
You should just be able to cut the holes and pop them in if there is room.
Another option is a microwave system like an Audiovox ROSS, it can install behind the bumper cover without any cutouts. I have one on our Chevy Express below the bumper(it won't go through the steel bumper) and it works great.
Old 09-23-2007, 07:18 AM
Default Wiring
There's space to pop them in but does anyone know how easy (or otherwise) it is to access the reverse light wiring so I can tap into this feed?
Thanks
Old 09-23-2007, 07:48 PM
N8Zvw's Avatar
Lititz, PA, USA
Car: 2004 New Beetle Cyber Green 1.8T, 1973 Red Beetle, 1974 & 2000 Beetles R.I.P.
I just installed my rear fog light and also keep it as a back up light. I used this thread on how to do it. http://www.newbeetle.org/forums/showthread.php?t=22157
Not sure if this is the area of wiring you are looking for.
Old 09-24-2007, 12:03 AM
Default Thanks...
for the link. Useful pics.
Mark
Old 08-19-2010, 09:55 AM
I just installed a parking sensor kits,The wiring is simple, finding the access hole took some time -there is one on the driver side and you will need to remove the back panel (in the trunk) to get at it, but it's only held on by two screws and some plastic tags.Once the wires are through you connect to the backup light - easy too - they are up under the trunk hood - red wire positive - white wire negative. The kit includes a small indicator light which also sounds the beeper. I installed it inside one of the air slots (vent for the battery pack) and routed the wire under the rear deck panel and into the trunk. This way, I can see it in my rear view mirror. So far, so good, very sensitive to movement (i.e., a child, or something). The only drawback was the price - 300 bucks. Hopefully it was worth it, will let you know.
Fan Sensors ? vdubs 2.0 Liter Gas 2 08-01-2007 03:19 PM
o2 sensors. puertorico 2.0 Liter Gas 2 05-05-2007 06:46 AM
best place for 02 sensors? 1idjack 2.0 Liter Gas 0 09-07-2006 01:28 PM
Reversing light price? Doodlebug Styling Modifications 1 07-30-2006 06:03 PM
How long do MAF sensors last? jpdeuce 1.9 Liter TDI 7 05-11-2006 03:20 PM
