These things definitely have a "short" problem somewhere in the headlight design...
I have had 4 or 5 "blown" headlights fixed by hitting the headlight or fender with some force. I have tried to trace it down, to no avail...
SMAUG - '98 UNI-RED NB TDI, UPSOLUTE, SPRINT 205's, EIBACHS, BILSTEIN HDs, CAT & MUFFLERECTOMY, .:R32 ARISTOS, GENERAL EXCLAIM UHPS, 250K AND CLIMBING
My drivers side headlight overheated the connector right at the lamp causing the connector to be loose in turn causing more heat. I cut the wire off about an inch and soldered a new connector on. No more problems.
I had the same problem like you, as Sooner bug said look at the wire connector behind the headlight mine was burnt like his and I did the same repair about a week ago. I just wish they would give you a little more wire to work with, its still working a week later.
| Door Handle Loose? | Kender | Questions, Issues, Concerns, or Problems with the New Beetle | 15 | 01-17-2008 12:47 AM |
| driver strut tower loose... | Silverbullet007 | Technical Modifications | 2 | 04-26-2007 07:00 PM |
| Driver Seat loose/rocks | 1pt8t | Questions, Issues, Concerns, or Problems with the New Beetle | 6 | 08-03-2006 05:29 PM |
| Loose tappet? | Beetlebomb | 2.0 Liter Gas | 3 | 04-14-2006 08:07 PM |
| Brakes seem loose | marvins_dad | Questions, Issues, Concerns, or Problems with the New Beetle | 7 | 01-24-2006 05:48 PM |
