Replacing window switch - NewBeetle.org Forums
Old 12-09-2007, 01:37 AM
Default Replacing window switch
I have been trying to replace a window switch in an 01 bug. I have tried two switches from the dealer and they both are not working. I swapped the passenger switch for the driver and that works. Is there something I'm missing?
Thanks
Need help on replacing power window cables. cblankin Technical Modifications 3 08-02-2007 02:16 AM
My car is screwed up after replacing brake light switch groebner Questions, Issues, Concerns, or Problems with the New Beetle 17 02-09-2007 05:34 PM
Replacing coolant temp switch jeff2761 2.0 Liter Gas 5 01-25-2007 11:55 PM
Lame turn signal sound after replacing Hazard Switch helga Questions, Issues, Concerns, or Problems with the New Beetle 4 10-06-2006 09:01 PM
Replacing the power lock switch drivers side gumaer 2.0 Liter Gas 6 06-16-2006 02:40 AM
