Headlight problems - NewBeetle.org Forums
Old 12-18-2007, 11:31 PM
Default Headlight problems
Good evening all--my daughter's 99 2.0l beetle has been causing me some grief with the headlights. The dim on the drivers side went out. I replaced finally after removing battery etc and skinned knuckles. 2 weeks later it went out again. I'm getting faster at replacing! She called me Sunday night and said the passenger dim went out. I have got it replaced yet. She called last night and now the drivers side went out. Since they're going out one at a time i think i can rule out DRL and Ebrake problem. Any thoughts or suggestions??
orren
Old 12-18-2007, 11:39 PM
bman's Avatar
Saint Catharines, Ontario, Canada
Car: 2000 GLX
If by chance you are getting your fingers on the glass part of the new bulbs, they will not last long at all. Oils and other nasty stuff deposited on the glass will create hot spots and cause premature failure.
If this is an issue, you can use rubbing alcohol and a lint-free wipe of some sort to clean off the glass just prior to insertion into the holder.
Otherwise, I might lean towards a wiring problem somewhere... perhaps an intermittent connection is causing arcing? You should be able to see burnt spots on the wires or connectors if this is happening. Also check your battery voltage with the engine running and the lights on. Use a digital multimeter and look for a voltage of fewer than 14 volts. It will be close to 13.6 or 13.8V at idle and perhaps 13.9V or even closer to 14V when the engine is running at 1500 rpm or above.
If the voltage is higher, the lamps will glow more brightly and fail sooner. I'm not sure how to remedy that, but it's an easy thing to check.
Problems reinstalling the headlight assembly PullMeUnder Questions, Issues, Concerns, or Problems with the New Beetle 6 08-30-2007 12:14 AM
'06-'07-- Anyone with headlight problems? deeceedub Questions, Issues, Concerns, or Problems with the New Beetle 8 02-26-2007 01:49 PM
headlight problems Brent Peterson Questions, Issues, Concerns, or Problems with the New Beetle 1 08-07-2006 05:06 PM
Right HeadLight coiae 2.0 Liter Gas 2 04-26-2006 10:25 AM
Headlight Help huskyfan_7 Questions, Issues, Concerns, or Problems with the New Beetle 4 10-03-2005 01:34 PM
