Me (Erin) ~ My car (Curby)
Mod Note: Fixed thread title.
Our Turbo S seats work only on 4 and 5. I have to be really cold to crank it up to 5, but 4 is very comfortable. I haven't seen any fixes for the lower numbers in the last 5 years, but that doesn't mean that there aren't any though.
Science flies you to the moon...Religion flies you into buildings
so is that a TS thing? Our '01 with leather seats works perfect at 2-3 setting.. we've never used 4 or 5 before
- Phil > '01 Volkswagen Silver Arrow New Beetle 1.8t (APH) > '95 Nissan Concord Gray 240sx turbo (KA24DE-T) |
i would say that you would get more out of the normal leather seats because they have the little holes in the leather. turbo S and sport seats dont have this so you might now get as much.
my GLX seats have always been full roast at 5, no perceptible heat at any other setting.
![]() just one of those things...i sorta remember a discussion about this on the old forums, and you might be able to fix it by replacing the switch...
Warren "And I think it's gonna be alright. Yeah, the worst is over now, the mornin' sun is shinin' like a red rubber ball." ![]() 1966, Paul Simon & Bruce Woodley. |
It has a strip of resistive material, the closer you place the knob wire to the end of the stip that has the other wire attached, the more juice that flows. Sometimes these resistive strips get dead spots. Remember the old volume controls that would have static when you turned them in certain spots? same basic thing. Replacing the switch should help. Or am I way off base and the newer VW/Audi cars have a different rotary control? ![]()
I've mentioned this before regarding this... our '03 was this way, where settings 1, 2, 3, and 4 had nothing in the way of heat, while 5 was nuclear. Dealer said it was "normal, leather seat don't help, they all work that way." Suggested I turn it to 5, then dial it back down to the preferred level. Didn't make a lick of difference.
Our '06, though, has definite gradations, I can definitely feel it from 1 on (a huge relief, since I figured the '03 5-setting might have left burn scars that would reduce my sensitivity in the lower regions), and with higher heat levels at higher numbers (with 5 still having the London Broil setting). Somewhere along the way, VW obviously realized their previous switch or heater coils or something wasn't quite right, and they successfully changed it... if it is the switch, maybe one can be retrofitted from a newer model...? They're identical... it might be worth asking your dealer, or finding a donor car in a wrecking yard and getting the switch for a few bucks just to try it... ![]() |
anyone thought of moding it? put a rocker switch where the stock rotary dial is, and below that add a dial, or wheel from an electrical outlet. if you get a dial you can have even finer adjustment than the 15 my aunts caddy has...
Matt |
Don't know if they even work, never used it. ![]()
wolfsbürgwe.:Rks Quote:
Maybe I have a more sensitive bum than others, but I feel the 3 setting in my TS. I usually keep it on 5 through these cold winter mornings, and crank it down to 4 or 3 later in the day. I just love having toasty cheeks.
2002 Black NBTS mods: S2000 antenna, chip coming sometime... dunno... Headlights on all day long since June 2007!
| Ouch!!! | jdesigns | Jokes | 7 | 06-17-2007 05:51 AM |
| Ouch! | MistressM | Paint and Body | 3 | 05-01-2007 09:33 PM |
| 02 TS Seat Heater Problem | glx2000 | 1.8 Liter Turbo | 8 | 04-25-2007 04:20 PM |
| Hot Seat !!!!! | exzotikbeetle | The New Beetle Experience | 11 | 09-21-2006 11:42 PM |
| Heater not as hot and blows cold when stopped | osprey | Questions, Issues, Concerns, or Problems with the New Beetle | 3 | 12-22-2005 11:22 AM |
