Headlight - NewBeetle.org Forums
Old 03-02-2008, 07:58 PM
MudBugjr's Avatar
Low rider
Tullahoma, TN, USA
Car: 2000' GLS 2.0
Default Headlight
I know there is a thread on here about it but My diver side light keeps blowing out.on my thrid bulb now. I know all about the bulbs keeping them clean and not touching them. I have to admitt I bought some cheap bulbs from AutoZone. The light housing is not the original and some of the wire coverings are peeling a lil . So should I just try a good set of bulbs for my low beams or do you think it could be the housing itself.
Old 03-02-2008, 10:41 PM
I've been buggered.
Timbuktu, NH, USA
If you are getting the palin-jane sylvania or GE bulbs, they should be just fine. Any specialty bulbs MAY burn out quicker. I had a few types of "blue" lights over the years and I stopped getting them due to quick burn-outs.
If you do just get vanilla bulbs, then the headlight harness may be bad. I think the aftermarket lights also reuse the stock harnesses, right>? And if not, does the stock harness fit your lights? otherwise, you'll have to whip out a soldering iron and just make your own replacements.
Old 03-03-2008, 01:02 PM
MudBugjr's Avatar
Low rider
Tullahoma, TN, USA
Car: 2000' GLS 2.0
I'm gonna try the better bulbs first. I have tried the blue cheapies each time thinking it would work. So back to the high dollar ones. Hope that works thats a lot cheaper than replacing the whole assembly.
Headlight help BobTdi Questions, Issues, Concerns, or Problems with the New Beetle 6 01-05-2012 05:04 PM
headlight bama bug 2000 Questions, Issues, Concerns, or Problems with the New Beetle 5 01-12-2007 01:53 PM
Headlight washers madison04 New Beetle Convertible 19 10-12-2006 12:20 AM
Right HeadLight coiae 2.0 Liter Gas 2 04-26-2006 10:25 AM
Headlight Help huskyfan_7 Questions, Issues, Concerns, or Problems with the New Beetle 4 10-03-2005 01:34 PM
