upper rear seat removal? - NewBeetle.org Forums
Old 03-09-2008, 02:11 PM
fuel110's Avatar
Ex Dub Owner
Huntsville, AL, USA
Car: 2006 Subaru WRX
Default upper rear seat removal?
does anyone know how to remove the upper half of the rear seat in an 01 tin top? I'm going to the drag strip today and that's one piece of hardware i can't for the life of me figure out how to remove.
Torrey Greene
Originally Posted by turbos03
best reply to a post on a internet forum, and the award goes to... fuel110
http://www.cardomain.com/ride/2734962
Old 03-09-2008, 04:49 PM
Too Cold NB1.8T's Avatar
Keep It Real
California, USA
There is a guide on each side between the seat and the inner wall in which the seatback rests, these guides rotate forward/backward, rotating each guide to the correct position will expose a slot that will allow the seatback mounting post to slide out thereby releasing the seatback for removal.
Old 03-10-2008, 05:55 PM
fuel110's Avatar
Ex Dub Owner
Huntsville, AL, USA
what about the center section of the seat where the bar runs under some sort of bracket?
Old 03-10-2008, 06:30 PM
sourmash's Avatar
Chelsea, AL, USA
Car: '01 Techno Blue TDI "Diesel Power"
Here's my process.
-Fold seat down
-Unzip the zipper in the center of the seat (well a little off center) and un-do the bolts (should be two allen bolts...can't remember the size though)
-Then take a flat head screwdriver and pry the retaining clips on either side to release the retaining pin.
You should then be able to just lift out the seatback.
The question is... When you turn your car on, does it return the favor?
The most stupid ad tagline ever, by Cadillac.
Rear Upper Stress Bar? Hollywood Technical Modifications 7 01-26-2008 08:44 PM
driver seat removal Jamel Questions, Issues, Concerns, or Problems with the New Beetle 6 03-16-2007 04:06 AM
Rear seat removal ChristopherC Questions, Issues, Concerns, or Problems with the New Beetle 4 03-09-2007 06:30 PM
Rear seat removal vgmnstr Styling Modifications 5 08-30-2006 06:55 AM
seat removal nbdude Questions, Issues, Concerns, or Problems with the New Beetle 0 10-15-2005 07:41 PM
