4 wire to 3 wire fan conversion??? - NewBeetle.org Forums
Old 06-04-2008, 08:37 PM
Default 4 wire to 3 wire fan conversion???
Is it possible to hook up a 3 wire cooling fan to a 4 wire beetle. I have a 2002 turbo sport. And the only fan I can locate new or used is a 3 wire hook up. Is there a way to bypass one wire or run the wire from side in tandam with the other, in turn making a 3 wire hook up?? Thanks for any help
Old 07-31-2008, 01:26 AM
I am having the same problem, the only cooling fans I can find are 3 wire and the stock fan and connector is 4 wire. Any one have an answer out there.
Old 08-02-2008, 09:58 PM
jc918t's Avatar
Tallahassee, FL, USA
Car: 1999 GLS 1.8t
Same story here, I am going to pop open my four wire fan to see where the wires go... if two of them hook up to the same terminal...then that is the answer...
I am hoping the red/black and red/white are the same terminal on the motor, just two different feeds. I will post my findings.
JC
Old 08-03-2008, 12:02 AM
jc918t's Avatar
Car: 1999 GLS 1.8t
Does anyone have a wiring diagram for the four wire fan?
there is a heavier gauge solid red wire.
a Red/white wire
a Red/black wire
and a brown wire - I know this is ground
Old 08-04-2008, 12:23 AM
doublebarrel's Avatar
Irving, TX, USA
Car: 2000 gls tdi
Brown/Black is ground
Red/White is low speed fan +
Red/Black is high speed fan +
Red goe's to the coolant thermal switch
Old 08-04-2008, 04:13 AM
jc918t's Avatar
Car: 1999 GLS 1.8t
Can the heavy gauge(Red)Coolant Thermal switch wire be combined with either the low speed input or high speed input in order to adapt a three wire fan?
Do Jettas that operate with two three wire fans incorporate a Coolant Thermal switch?
If they do and it goes into the control unit, could I simply swap out the fan control unit from a doner MkIV Jetta?
vag-com connection wire catsnet Market Place Archives 3 06-07-2007 02:29 PM
vag-com connection wire catsnet Market Place Archives 0 05-26-2007 04:08 PM
tach wire brasdl 1.9 Liter TDI 2 11-24-2006 04:58 AM
ABS Wire jazzman_q 2.0 Liter Gas 0 07-18-2006 11:28 PM
Cd Changer wire....where is it!? 1poorvw 2.0 Liter Gas 3 03-13-2006 09:26 PM
