Need diagram of '06 beetle left side rear backup light assembly removal - NewBeetle.org Forums
Old 01-25-2009, 06:03 PM
hestersu's Avatar
Canyon, TX, USA
Default Need diagram of '06 beetle left side rear backup light assembly removal
Does anyone have a Bentley that covers the '06 beetle that shows the removal for the left side rear backup light assembly? I could sure use a step by step on the removal. A scan or screen shot would be nice too.
TIA
Susan Hester
Former owner of:
Old 01-27-2009, 11:00 AM
CGK's Avatar
Beetleman
Salisbury, NC, USA
Here's the procedure from Bentley. Hope this helps
Old 01-27-2009, 02:35 PM
hestersu's Avatar
Canyon, TX, USA
Thank you so much! I have printed this and will use it soon I hope.
Did this come off of a Bentley CD or out of the Bentley book? I'm considering getting a VAG-COM from Ross-Tech but use a MacBook Pro. I have VMWare Fusion and Windows Vista for Business loaded. From what I can tell, the Vista behaves like it was any other PC - it just runs under Mac OS X. Ross-Tech makes no promises that it there stuff will work under this scenario. I can also get a discounted version of the Bentley CD if I purchase at the same time as the VAG-COM.
Thanks again. I appreciate your time on this.
Old 01-27-2009, 04:36 PM
CGK's Avatar
Beetleman
Salisbury, NC, USA
I sent you screen shots from the CD. The same pages are available in the Bentley Service Manual as well.The manual is very comprehensive and has everything the CD has except the repair procedures for DTC's (Diagnostic Trouble Codes). The CD gives the test procedures and repair procedures for sensors and the like that are causing the code. I'm not sure if VCDS (Vag-Com) will work with your PC setup but I can tell you that it's an extremely valuable tool to have if you want to analyze anything about your NB. I have used it many times to test for DTC's and to run diagnostics on many modules in my two NB's and my Passat. Check out the Vag-Com forum on VWVortex for more info or contact Uwe at Ross-Tech.
You can't go wrong with either the CD, manual or VCDS. I have them all and they have saved me from having to spend big bucks at a dealer to analyze and repair my rides!
Good luck with your decision!
Clear side LED marker light removal???? Need Help! jsw5620 Technical Modifications 5 11-05-2011 01:11 AM
WTB Pass side rear marker light 05 Titchy Parts and Accessories 0 07-06-2008 09:08 PM
WTB: 1999 Beetle Driver Side Door Latch Assembly caybeetle Parts and Accessories 10 05-27-2008 03:36 PM
Rear side marker light Lmhansen Questions, Issues, Concerns, or Problems with the New Beetle 4 06-20-2006 12:14 PM
2002 Beetle clicking noise rear left... help? DonaldLL Questions, Issues, Concerns, or Problems with the New Beetle 3 12-12-2005 05:22 PM
