2006+ New Beetle Headlight Removal - (How-To) - Discussion Thread - NewBeetle.org Forums
Old 03-31-2009, 08:05 PM
noR's Avatar
Administrator
Jackson, MS, USA
Default 2006+ New Beetle Headlight Removal - (How-To) - Discussion Thread
This thread is for Discussion on the How-to titled:
How-To: 2006+ Headlight Removal <---click on title to go to link.
noR | me | Phrog
PHROG
Old 03-31-2009, 10:00 PM
antonym's Avatar
¯\_(ツ)_/¯ (o\_l_/o)
Car: 2013 Kia Rio-5
WOW!
This is an EXCELLENT write up!
Good Job HP!
Old 03-31-2009, 10:59 PM
miffmole's Avatar
NBC Driver
SC, USA
Very good...I think even I might have a chance with that kind of help...
I'm assuming that, since it says +06, then that's what it means. I don't have any problems with headlights right now, but looking down the road, are factory HIDs changed the same way? What bulb? Are they pretty durable? Mine is an '04.
I hope so.
Old 04-01-2009, 03:45 AM
HarlequinPixie's Avatar
ElectricHarleyHouseOfLove
Currently: Williamsburg, VA, USA
Car: 2001 Batik Blue 2.0 GLS 5spd
haha. i just did the grunt work and a bit of editing.. i've never even seen the engine compartment of an 06+ in person.
but to answer miffole's question... the headlight assembly on the earlier ones is different. I would imagine there's a writeup somewhere for them though
Old 04-26-2009, 03:43 AM
Keep on keepin on!
Los Angeles, CA, USA
Car: 2008
i had a poor attempt to describe this before but the pictures speak a thousand words.
Consider carefully about "upgrade" bulbs. Originally i purchased the Silverstar bulbs. Those lasted 4 months before they blew. I then tried some aftermarket Japanesse bulbs from Ebay in and the bulb glass melted and distorted.
I now have the Silverstar Ultras in and time will tell how long those last.
It is apparent that there is a large amount of heat build-up in the projector-style housing where the bulb goes, so be very careful when deciding to go with other lights other than OEM. I would advise to not go with any higher wattage than what the original bulb has.
Old 06-04-2009, 04:18 AM
salsa-man's Avatar
Bugaholic
San Antonio, TX, USA
Car: 2006 NBC Pkg 2
Thanks to all for this EXCELLENT guide for replacing headlamp bulbs. I bought a set of Sylvania Silver Star Ultras right after I bought my Beetle the other day. When I Opened the hood to see how to get at the bulbs I nearly passed out. I thought this was going to be really complicated. So came to this GREAT website and located this tutorial. Worked like a charm. However, a word of caution - don't do what I did and not get the 5mm latch re-secured. I thought I did but then had problems where the lights were intermittently coming on and off. The electrical connector apparently is VERY sensitive. While the headlight housing was pushed into the fender as far as it would go, there was just enough play in that electrical connector to make it unstable. That latch indirectly secures the electrical connection. So take care to get that latch fastened properly.
Old 06-06-2009, 08:19 PM
MountainBug's Avatar
Too Much Time In Thin Air
Conifer, CO,
Car: 2006 TDI Pkg 2
I've got a deisel - and the pictures don't match up at all except for the 90 degree lever.
Help (anyone) ? There doesn't seem to be a lever to pull down on (?)
2006 Salsa Red TDI MountainBug!
http://members.rennlist.com/Mountain914/Bug.html
Everything is cooler at Altitude!
Old 06-08-2009, 03:46 AM
Judee's Avatar
I Love Hippos.
San Diego, CA,
Car: 2008 Beetle S
This post is one the most helpful posts ever! Pictures and everything!
Personally I found the right side to be more difficult since you could barely see the aluminum lever below/behind the battery tray. Posting pictures of that would be most helpful for others.
I ended using an extension to press the lever down, another extension to pry the headlight out from behind, and my leg to keep the headlight from sliding all the way out... talk about a yoga exercise!
I would not have figured that out without this thread!
I'll post some pics as soon as I get my HIDs figured out.
Old 06-11-2009, 09:19 PM
salsa-man's Avatar
Bugaholic
Car: 2006 NBC Pkg 2
Originally Posted by MountainBug View Post
..... There doesn't seem to be a lever to pull down on (?)
It's there. It's just difficult to figure out what IS the lever amongst all the other surrounding parts. Here are some extra pictures that may help you find it.
A few tips: 1) Removing the battery cover on the left side REALLY helps to locate the 5mm screw and the lever. Use a 1/4" extension about 18 incehs long to press down the lever. Use a wooden stake to pry out the headlight housing while holding the lever down.
Old 08-26-2009, 03:53 PM
pvpeacock's Avatar
Palos Verdes Estates, CA, USA
Car: 2006 Convertible
Great "how-to"!!! The driver side low beam bulb went out on my 2006 the other day. When I opened the hood, I had no idea how to access the bulbs or remove the headlamp. I was resigned to taking the car to the dealer (with all the hassles that go with it) until I found this post. There is no way I could have ever figured out how to replace the bulb without this great "how to" post. This is what makes the web and this site great. Thanks!
Note: the 2006 takes the H7 bulbs for low/high beams.
Ka Pu'u
Old 08-29-2009, 04:43 PM
Judee's Avatar
I Love Hippos.
San Diego, CA,
Car: 2008 Beetle S
It is done... http://newbeetle.org/forums/photos-o...6k-beware.html
Old 12-09-2009, 09:04 PM
cep's Avatar
Who is John Galt?
Grubsoil, KS,
Very thankful to have found this post today.
I'd changed bulbs in our '02 and thought I knew how...but deep in the memory I thought I'd read that something was different on the '06.
Sure is. I'd have never figured it out.
FWIW, on the diesel, you can get your hand in by the fuel filter to hold down the sheet metal 'lever'. No tool needed.
Quite a shock at how expensive these bulbs are, though. I didn't have time to shop and paid ~$16 for one.
I think I like the '02 arrangement better. Not only is it easier, the bulbs are cheaper and ours lights up the road better than the '06.
'02 & '05 Acura RSX
Dodge Cummins, Ford Ranger
M151 Ford
Old 12-09-2009, 11:53 PM
Beetlescott's Avatar
USS ERNIE PRISE NCC 1701
LOUISVILLE, KY, USA
Is there a link that shows how to take the earlier ones out?
Old 08-07-2010, 05:18 PM
Peoria, IL, USA
Car: 2008 New Beetle SE
Thumbs up
Thank you for this. Ran with driver side out for a couple months until the passenger side blew.
As an addition, if either doesn't light up when replaced give the lens a few pats to help seat the plug on the assembly into the socket on the housing more.
Old 10-08-2010, 01:32 AM
SixChuter's Avatar
Bixby, OK, USA
Car: 2008 3W/2004 TS
I changed a headlight in '04 a few weeks back and had no trouble. Unfortunately i just lost my first one in Lily. It is on the driver's side. I have a simple question. In the group of pics it shows turning the headlight lock 90 degrees clockwise on the passenger side. On the driver's side headlight, do you turn the headlight lock clockwise or counter?
If you don't know where you're going....any road will take you there. G. Harrison
Lily's Pics
Gandalf's Pics
My Profile Album
Old 11-04-2010, 12:50 AM
cep's Avatar
Who is John Galt?
Grubsoil, KS,
Counterclockwise.
Old 07-09-2011, 08:07 PM
CO, USA
Car: 2006 Silver New Beetle
Oh my gosh, this is so helpful! I couldn't figure out how to take the right bulb out. Thank you so much!
Old 08-27-2011, 02:02 AM
Springfield, MO, USA
Car: 2006 NBC Package #2
Default Help!
Anyone have a shot of the LH (drivers side) with the lamp housing removed? I broke the locking mechanism removing the lamp housing and can't get it to lock. There's just one little piece of plastic cracked on the outboard end of the clamping rod. I'm hoping I can figure out a kluge to get it locked without having to replace that plastic receiver. Any photos showing how this thing is supposed to look would be appreciated.
Old 08-27-2011, 11:20 PM
Speedtek's Avatar
VAG, it's a lifestyle...
Prince Albert, SK, Canada
Car: 2004 Turbo S
I wonder if the 06+ mounting setup would retrofit into a 2004 chassis?
I absolutely detest the headlight mounting system in mine..........what a POS
Old 10-04-2011, 03:45 AM
jhawk_2861's Avatar
Leander, TX, USA
Car: 2006 TDI DSG Pkg 1
Anyone have an idea about removing the lens on an '06? I've seen a how-to for pre-06 models, but the 2006 changed that process. I've been digging around for a while and can't find anything anywhere! My lenses where so yellowed when I got the car that I bought two complete replacement headlight assemblies. They were OEM but used, so I was able to get a pair for about the price of one new headlight. As we all know, you get what you pay for! After a couple of months, I went through the car wash and my driver side light blew out. Apparently the original owner bottomed out and cracked the front bumper cover enough to create a small gap near the driver side headlight. (that dang front bumper cover is another thing that I can't find!) So, I knew about the cracked bumper cover. What I didn't know was that the used headlight that I'd purchased had deteriorating plastic around the wiring (socket?) for the low beam. That got fried from the high pressure water so I popped the original back in. Now Ringo McRattles looks like he has a black eye and I don't want to buy another complete assembly. I just want to swap the good lens onto the good assembly! I will probably just end up cutting the fried socket off and splicing the good one on, but if anyone knows of a lens swap method, then that would be awesome, too! Thanks in advance
Front Grill Removal - (How-To) - Discussion Thread marvins_dad Styling Modifications 58 08-14-2011 03:36 AM
How-To: 2006+ Headlight Removal HarlequinPixie Technical How-To 1 03-31-2009 08:09 PM
New Beetle 1.8T Boost Gauge / Pod Install - (How-To) -Discussion Thread marvins_dad Technical Modifications 4 11-20-2008 11:32 AM
2006 headlight removal Maggadog Questions, Issues, Concerns, or Problems with the New Beetle 1 03-17-2008 06:03 PM
Texas New Beetle Round-Up 2006 - Photo Thread marvins_dad Photos: Get Togethers 20 04-06-2006 03:26 PM
