Spring Upgrade - 'Vert Springs on a Sedan - NewBeetle.org Forums
Old 07-31-2009, 02:17 AM
BUGSTUFF's Avatar
New Beetle Accessories
Bartlett, IL, USA
Default Spring Upgrade - 'Vert Springs on a Sedan
Because we occasionally tow stuff with our NB (and I hate a saggy butt) I thought it would be a good idea to put a pair of convertible springs in the back of our '98. Replaced the springs, shocks and rubber pads and gained a bit of height in the rear. Minimal sag when our cargo trailer is hooked up. Yay!!!
So, since I was replacing the front struts and bushings anyway, I thought it might be a good idea to put the 'vert springs on the front as well. You know - matched set, the old ones were 10 years old, etc....
Took it to the dealer since I didn't have the tools to do the fronts myself.
Went to pick it up and I was a bit shocked - no pun intended - the NB looked like it had been fitted with a 4x4 lift kit!!!
Definitely not what I had intended. I've given them a couple of months to "settle" but to no avail.
I'll be taking it back next week to have the old front springs put back on.
Here's a couple of pics - the bottom of the front valance is 8 inches off the ground - a bit too high for my liking.
So, if anyone would like to buy a pair of OEM front 'vert springs and a pair of rear stock springs, LMK.
Kirk & Pam & "Key Lime"
Northeast IL VW Association
Volkswagen Club of America
Old 07-31-2009, 02:58 AM
DZLBUG's Avatar
I Am Breitbart
Sauk Rapids, MN, USA
What are the color codes on the front springs? Which year/engine did you order them for?
I may be interested...that is a surprising amount of lift. Goes to show how much heavier the 'verts are.
2000 New Beetle GLS TDI
Old 07-31-2009, 04:09 AM
hestersu's Avatar
Canyon, TX, USA
Dang those wheels look nice.
Susan Hester
Former owner of:
Old 07-31-2009, 04:23 AM
BUGSTUFF's Avatar
Bartlett, IL, USA
Thanks Susan!
DZL - I'll check the color code after I get them removed.
Old 07-31-2009, 11:08 AM
doublebarrel's Avatar
Irving, TX, USA
Car: 2000 gls tdi
I'd love to have that much ground clearance.Can you get the part #s on those springs?
Old 08-31-2009, 06:08 AM
DZLBUG's Avatar
I Am Breitbart
Did you get these removed yet? How much you want for them?
I'm guessing these were for a newer vert with the 2.5? That would be the heaviest spring available due to the 5 banger. You might have better luck with vert springs from a 4 cylinder model.
Old 09-19-2009, 07:47 PM
BUGSTUFF's Avatar
Bartlett, IL, USA
Front springs are off and ready to ship. They came from a '03 or '04 2.0 NB convertible. Paint code - 1 Violet and 1 Green dot. Part number may be 1J0 411 105AP
The rears are from a '98 2.0 hardtop. Paint code - 2 Blue Dots and 1 Silver dot. Part number 1J0 511 115 AG.
DZLBUG has dibs on the fronts but the rears are available to anyone who has a broken spring or might want to return to the stock setup.
Old 04-29-2010, 03:21 AM
wasilla, AK, USA
Car: 1999 new beetle. 2 liter
how was the handling effected?
Old 04-29-2010, 04:07 PM
BUGSTUFF's Avatar
Bartlett, IL, USA
Slightly firmer ride, but I changed the struts and shocks as well. You don't really know your shocks are bad until you replace them and feel the improvement.
Front springs are sold BTW, but the rear stockers are still available.
Old 05-17-2010, 03:46 AM
wasilla, AK, USA
so i have a 99 new beetle and i want to do the spring upgrade you did. what am i looking for.
as in what year convertable (or other vehicle like jetta wagon?) springs would be a direct fit replacement.
and what shocks/struts do you suggest....would you just do the convertable shocks and struts....or just ones for the regular nb?
sorry for the dumb questions
Old 05-18-2010, 05:24 PM
BUGSTUFF's Avatar
Bartlett, IL, USA
The springs came off a '03 or '04 convertible. You could probably use the MKIV Jetta Wagon springs as well, but they might be too stiff. I put the stock front springs back on because the front was too high for my liking with the 'vert springs.
I just went with a set of Monroe Sensa-Trac shocks & struts, which are fine for what we use the car for. I'm not sure if the shock manufacturers differentiate between sedan and convertible.
Good luck!!!
Old 05-21-2010, 09:55 PM
72SuperBeetle's Avatar
Wienerdude
Elk Grove Village, IL, USA
Car: 03 1.8t Beetle, 01 Jetta 2.0
The best oem wheels offered, in my opinion!
I swear my real name is not "Wienerdude"
2003 1.8T Beetle
2001 Jetta 2.0
Old 05-21-2010, 10:15 PM
BUGSTUFF's Avatar
Bartlett, IL, USA
Default Sunset Wheels
You are correct sir!!!
Old 05-25-2010, 03:16 PM
wasilla, AK, USA
any clue if factory springs off an mk4 jetta would provide any lift.
a guy just moved in across the street and he has his stock springs.....lowered his car sometime ago.
i dont have the color code or anything.....any suggestions or thoughts?
Old 05-26-2010, 03:45 AM
BUGSTUFF's Avatar
Bartlett, IL, USA
They will fit, but unless it's a wagon there probably won't be any difference from the ones already on your NB.
Jetta Wagon or NB convertible are probably your only options.
2010 Porsche Panamera: Porsche's first-ever 4-door sedan goes on sale in the U.S. antonym Rumors and Insights 36 11-05-2009 11:14 AM
1st Annual Mountian Top VW Clubs Heber Springs Car Show-Heber Springs Arkansas Ghia_Roadster USA: Southwest 0 04-27-2008 02:20 AM
PlatEdLoveBug's 2006 2.5L Sedan Reflex Silver PlatEdLoveBug Photos: New Beetles 18 12-24-2007 02:29 AM
NB sedan vs vert visibility ? n2jesus4life New Beetle Convertible 3 07-02-2007 02:36 PM
FS: Beetle Sedan sunglass holder in gray jsapero Market Place Archives 1 06-11-2007 04:46 AM
