Upsizing 16" OEM tires - NewBeetle.org Forums
Go Back   NewBeetle.org Home > NewBeetle.org Forums > 1998-2011 New Beetle > Modifications > Technical Modifications
Old 08-22-2009, 03:40 PM
mel72349's Avatar
Randallstown, MD, USA
Car: 2006 TDI
Default Upsizing 16" OEM tires
I'm ready to replace my 2K6 NB TDI's OEM 205/55R16 tires on after-market 16"X7" wheels. I'm considering 60-aspect tires for a little more ground clearance.
For anyone with first-hand knowledge, will 205/60 or 215/60 16" tires fit without rubbing?
Appreciate your help.
2K6 Dweezil DZL BTL
http://mefi.us/images/fuelly/sig-us/15472.png
Old 08-22-2009, 04:39 PM
DZLBUG's Avatar
Probably MIA
Blaine, MN, USA
You could probably squeeze in 205/60/16 on stock suspension. 215/60/16 will probably give some rub but would likely still work. If you want more ground clearance than that, a 1" or 2" Metalnerd lift would be in order.
Remember that changing tire size will change your odometer and speedometer readings. In the case of the speedo, it will make it much more accurate as VW makes it under-report 3-5%. The odometer however will show less miles than you are actually putting on with the larger tires.
2000 New Beetle GLS TDI
Old 08-22-2009, 06:27 PM
The Cheat's Avatar
overwhelmed/underpaid
New Britain, CT, USA
205/60 will clear stock suspension.
215/60 will not.
i would run a 215/55 over all else for one reason: it's VERY popular in the japanese midsize segment. lots of great tires to be had.
Old 08-22-2009, 09:32 PM
DZLBUG's Avatar
Probably MIA
Blaine, MN, USA
215/60 will not.
215/55 run about 25.3" to 25.4" diamater.
205/60 run 25.7" or so.
Stock 205/55 is 24.9"
The 205/60 will give him a better ride and about 0.4" in ride height. The 215/55 will give only 1/4" at best and not as good of a ride.
Tirerack shows 69 tires for 205/60 and 64 tires for 215/55.
Old 08-25-2009, 12:44 AM
The Cheat's Avatar
tire opinions are like farts though, so everyone's mileage may vary.
i ran 215/55 on my nb with no problems, in fact, i noticed it handled MUCH better.
conversely, my jetta handles better on 195/60 tires over the 195/65s.
try out the 205/60s, if you're looking for low resistance, there's a michelin in that size found on the accord hybrid that is supposedly GREAT.
in 215/55, you can get a real nice sporty tire (i had some off-brand equivalents to the toyo fz4).
Old 08-28-2009, 04:56 PM
Turbomania's Avatar
Returning senior member
Dallas, TX, USA
Car: 99 grn/Blk leather,1.8 T,5-sp, Eibach springs & Damped, -2"frt.-1.5" rear. 2.5 Tectonics SS ex, K%N
Default Size matters, esp. for tires...
I replaced my OEM 205/55-16 tires with 225/50-16 tires the first time I needed to get new tires. The ride was harsher but the handling and cornering were spectacular! Right after that I had an Eibach Pro-kit spring and damper kit put on my car to improve handling even more. My front end dropped about 1.8 to 2"'s with the rear dropping about 1.8"'s. With the 50 series tires and the slight drop in vehicle hight I did have to be more careful of parking blocks and higher than normal obstacles but the handling was worth it. Now I have a set of Continental Extreme Contact 215/55-16 tires which are absolutely some of the best all year round handling tires I have ever driven on. The ride did improve like I thought it would but it still maintains great handling. Check on The Tire Racks charts to see how wide a 225/50 series tire is and that will tell you how wide a tire will fit. Mine didn't rub much at all except when the suspension was at the very bottom of it's travel... Good luck, JK
Turbomania
Old 09-05-2009, 09:40 PM
cpoore's Avatar
Martinsville, IN, USA
Car: 2006 Beetle Tdi
I'm running 225/60/15 in front with not rub. Rear is 255/60/15 and on a huge bump... maybe some. But 2" lift is coming next week. The car handles better and rides better. I would guess on size up from 225/60/15 would be 215/60/16. My speedo is off tiny percent compared to my GPS... maybe like 1-2 mph if that.
I got my specs from a Japanese site. Bugsgogo.com I emailed the owner of the Light Blue Convertible running taller tires to find out who they did it.
Take it easy -Chad
06 TDi Beetle: 15" Keskin on BFG TAs w/2" Lift. w/Canoe on roof My old garden. My old rides, still got the 65 van!
1979 35ft Bluebird Wanderlodge: Alcoa rims, 6 General 11R 22.5, 3208 CAT, original w/80k and the Beetle rides in an enclosed 22ft trailer... not for the timid
Remember to nominate those special folks with a Darwin Award.
Old 02-27-2011, 03:40 PM
Lew's Avatar
LewRegistered Member Lew is offline
SE, GA, USA
Car: 2005 Beetle GLS TDI 5 Speed
You only widened your tires 3/4" by going to the 225 from the OE 205's.....I am planning on going to the 225/50/16 just to put a little more rubber on the ground.....Not sure what you meant by the ride being much harsher with the 225/50/16's, and why did you go to the 215's?
Central Florida TDI Club
Wife's 2005 manual with RC1+ Rocketchip just sipping Beetle Juice 47.5 MPG Avg on Fuelly.com. Ross Tech Vag Com!
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Include me on the map?
Log-in
Human Verification
You may post new threads
You may post replies
FS: (4) 16" "Mali" wheels w/out tires - $300obo - Milwaukee, WI mertonbeetle Market Place Archives 3 04-16-2010 03:45 PM
Feeler: 18" OZ Aristos with new tires and 16" steelies with Pirelli snows turbobug17 Market Place Archives 8 04-06-2007 02:11 AM
17" vs 16" rims/tires question mosgood Questions, Issues, Concerns, or Problems with the New Beetle 3 01-30-2007 06:00 PM
FS: (4) Mille Miglia HT-3 Grey 18" x 8" Wheels with Kumho Ecsta SPT Tires r0nd3L Market Place Archives 10 01-27-2007 07:14 PM
"Mint" 2002 NB Turbo S Wheels & Tires Hollywood Market Place Archives 5 12-28-2005 06:12 PM
