swap? or not? - NewBeetle.org Forums
Old 01-29-2010, 03:09 AM
springport, IN, USA
Car: 1999 VW Beetle 2.0L efi gls
Exclamation swap? or not?
can i swap my 1999 2.0 for a 1.8t 1999( will it be plug and go?)
Old 01-29-2010, 04:29 PM
easy answer is .... NO.
there are too meny reasons why to list.
it will bolt in, thats the easy part. the rest is the hard part.
Old 01-29-2010, 04:38 PM
DZLBUG's Avatar
I Am Breitbart
Sauk Rapids, MN, USA
It could be done, but why build what you can buy? If you have an entire parts car (one that had been rolled for example) for cheap...and you don't mind doing a lot of work...go for it.
It would require a different harness, ECU and cluster, exhaust and possibly other things. The transmission ratios are different as well. Unless you had a parts car to swap everything off of, its not worth the time and expense when you probably have 10 or more 1.8T NB's for sale within driving distance. As long as the 2.0 is in good running condition and you don't owe much/anything on it...go trade it for a 1.8T...done.
2000 New Beetle GLS TDI
Old 01-31-2010, 11:06 AM
Fl_bug's Avatar
Catch me riding s00ty!
Miami, FL, USA
good point there DZLbug
Tags
engine swap
99 2.0 gas swap for ??? huck731 Engine Swaps 13 10-21-2009 01:45 PM
2.0L AEG swap for 2.0L ABA customnb Engine Swaps 6 11-19-2008 07:30 PM
2.0 to TDI swap macdave 1.9 Liter TDI 3 05-25-2008 02:09 AM
I know its been gone over before... VR6 swap.. Holland Engine Swaps 2 06-30-2007 01:01 PM
1.8t swap ????'s gtpon22s 1.8 Liter Turbo 0 02-28-2007 11:08 PM
