NB Convertible springs - direct replacement, no modifications needed. I installed a set on the rear for towing and they are perfect. I installed the fronts as well but they were a bit to high for my liking. So...I have a pair of fronts for sale that will give you about 1 1/2 to 2 inches of lift.
Kirk & Pam & "Key Lime" "BUGSTUFF" - Unique New Beetle Accessories Northeast IL VW Association Volkswagen Club of America "Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways - Crown Royal in one hand - Cigar in the other - body thoroughly used up, totally worn out and screaming "WOO HOO, What a Kick Ass Ride!" |
Jetta wagon front springs(with 2.8 engine)and 2006-2008 New Beetle springs(with 2.5)are the same.O.E. part# 1J0411105CD,paint code 2 blue,2white.They should give some lift.You can add 10mm front strut spacers(O.E. part #1J0412311A)for more lift.On the rear Jetta wagon springs,same as 2006-2008 New Beetle O.E. part# 1J0511115CP,paint code 1 white,4 brown should give lift.They are stiffer springs.The best price I found on these was from "VW Parts" - "Volkswagen Parts" - Parts and Accessories Catalog. ,they are around $90 each.
Talk to DZLBUG
(o\_I_/o)2004 TS::. Reverse engineered from UFO's(o\_I_/o) |
Here's some pics.....
http://newbeetle.org/forums/styling-...ngs-sedan.html Installed with a brand new set of Monroe Sensa-Trac struts and shocks. |
Neil |
jetta wagon rear springs will def give you a lift.
we istalled a set on a bio diesel mk4 golf that had alot of extra weight in the rear, worked great, way better then "heavy duty" springs.
http://www.takepart.com/foodinc/ |
After more research and reading. Looks like I will do some 2" spacers.
The Metalnerd ones are over priced IMO. $300 bucks with a $100 refund is retarded. All they are is milled AL spacers. I can Mill some out of AL myself for cheaper than that, and make the shock brackets as well. Now with that out of the way I guess I'll do the O.E. part# 1J0411105CD,paint code 2 blue,2white for the Fronts. As it will give lift and have little better Spring rate than my OE ones, hopefully not to stiff! For the rear I tow alot, so would the 2006-2008 New Beetle O.E. part# 1J0511115CP,paint code 1 white,4 brown be to stiff when un-loaded, yet lift as well? I was surprised how well the stock rear springs do loaded they look so small! I am going to order the suspension rebuild parts here soon and the new Bilstein TC front and rear. Then when they come in I can mill the front spacers. Then order the springs front and rear and mill the back spacers. Thanks! |
Already I put the rear springs int to see what they looked like as I am still waiting on front springs and the rebuild kits.
But man they added about 2" of lift at least!!!! I swapped the stcoks back in till I get the new fronts as well. I can't wait to get everything installed! I'll post pictures and take measurements of the lift. |
alright.
this is good stuff. so does anyone know of what springs i can get to replace my stock springs on my 99 nb 2.0? im shopping the junkyards....and a list of different vehicles that i could pull these from would be fantastic. im looking to get as much of a lift as i can with just upgrading shocks/struts and springs....and of course the minor suspension hardware if need be. this is the first ive heard of anyone using the vert springs....are they really usable on a 99? thanks for all your help also, what shocks and strust...mine dont seem very worn, but i cant see taking the suspensin apart and not replacing them while im at it....kyb? bilstein? |
| 6-speed transmission rebuild? | spinjector | 1.8 Liter Turbo | 0 | 09-17-2009 11:30 PM |
| Rebuild calipers? | MichelleRoze | Questions, Issues, Concerns, or Problems with the New Beetle | 2 | 08-05-2009 04:19 PM |
| Sport suspension or regular rate suspension? | fohveh | Questions, Issues, Concerns, or Problems with the New Beetle | 1 | 02-12-2009 11:17 PM |
| Engine rebuild? | bonnie | 2.0 Liter Gas | 8 | 05-22-2007 01:45 PM |
| instrument cluster rebuild? | Buzzfish | Questions, Issues, Concerns, or Problems with the New Beetle | 4 | 04-30-2007 09:29 PM |
