Hey everyone, I have a 2001 New Beetle 2.0 I recently bought and the cruise control hasnt worked since the day I bought it when you turn it on it doesnt show anything on the dash. So i looked in the fuse box by the speedometer and there weasnt anything i could see relation to the cruise control.. Where is the cruise control fuses under the hood with the battery? Any help would be great thanks.
Side note, if you need to get a scan of your system for errors, most of your local parts shops like Schucks auto parts, and places like that, will check your system for free. VW usually charges for that sort of thing.
Just thought I'd mention ![]()
Bumbls : 2011 Ford Transit Connect XLT
Sting : 2002 1.8T Beetle Color Concept My FLICKR: See My High-Res Photos Here Cameras I Use: Canon Eos 40D |
thank you both so much for your answers. I took it to autozone to get the codes read the only one was for my coolant sensor I believe. So i will be purchasing that from ecs soon.
Also Sorry for all of the questions. Judy has been making some weird sounds about 2000 rpm like the exhaust is loose or something but when I got my oil change done at a independent dealership, they said my power steering hoses were leakinga little. Does anyone have any ideas? |
I would wipe all the hose connections and hoses of any fluid, make sure the reservoir is at the correct level and check the tightness of the hose connections. After doing that wait and see where and if any leaks start appearing. I prefer VW's hydraulic fluid that they use for the PS system. It's not expensive and is available from your local VW parts department. It's compatible with all the inner seals, etc. inside the rack and the pump. JK
cruise control is a codeable option, I belive its in the ecm, all you have to do is turn it on, my guess is at some point someone had to replace or re flash the ecm and didnt program the cruise, even I have forgot on custs cars at times, its easy to forget.
| Tags |
| 2.0 , control , cruise |
| fuse 34 10amp, Engine Control Elements, FUSE BLOWS | frankgant | 1.9 Liter TDI | 1 | 10-21-2009 04:57 PM |
| wtb fan control unit and fuse box | GLUVBUG | Parts and Accessories | 0 | 05-19-2008 06:35 PM |
| Cruise Control | vwbugirl2 | Questions, Issues, Concerns, or Problems with the New Beetle | 1 | 03-14-2008 09:36 PM |
| cruise control | fiveshoes | Questions, Issues, Concerns, or Problems with the New Beetle | 0 | 06-16-2006 09:21 PM |
| cruise control | albroumand | Questions, Issues, Concerns, or Problems with the New Beetle | 1 | 11-15-2005 02:42 PM |
