Working on a friends NB.
She sometimes has to crank it twice in the mornings, especially when its cold and makes a grinding sound. When it's warm, it stops and starts the way it should. However, I measured 12.47 volts at the battery. The Alternator is pushing out 96 amps. The load test is good. Its sitting at 14.74 volts while running. parasitic drain at 41 mA. (aftermarket radio memory) However, spec on the starter is 140 amps. the starter current draw test is pushing 161 amps. I have not measured voltage drop or resistance on the ground, because I do not believe that is the problem. I am curious if the you would consider the 161 amps, excessive enough to junk it and get a new one. The car chargers fine, cant be the charging harness. Measuring full voltage at the ignition switch as well. Im pretty sure the diagnosis is correct. Anybody want to confirm? Throw in their two cents? |
| Question for a seasoned Tech. | Pseudotropheus | Technical Modifications | 11 | 03-02-2010 04:55 AM |
| Swapping front seats-tech question | mel72349 | Technical Modifications | 19 | 09-07-2006 07:42 PM |
| dub-tech.com is BACK!@ | Growler | Miscellaneous Hoo-Ha Archive | 3 | 08-27-2006 01:12 PM |
| Need some Tech . input .. | bugsy98nb | Miscellaneous Hoo-Ha Archive | 3 | 01-13-2006 03:27 PM |
| Tech Question | BlackBug | 2.0 Liter Gas | 3 | 12-27-2005 12:43 AM |
