change manual to oem auto mirror in new beetle - NewBeetle.org Forums
Old 02-23-2010, 02:27 AM
Default change manual to oem auto mirror in new beetle
Anyone change from a manual dimming rear view mirror I have in my 2006 New Beetle convertible to a AUTO OEM rear view dimming mirror? PROBLEMS?
Old 02-23-2010, 06:22 AM
Deserion's Avatar
Moddin' Lion
Jacksonville, FL, USA
Car: '95 E320, '04 986
It's plug & play, well it least it was on my '00. The only "problem" is the cost.
Previously:
Old 02-23-2010, 12:19 PM
Duffy's Avatar
Duffy II
Jonesboro, AR, USA
Car: 2009 NBC Harvest Moon
Well, if the 2006 is like my 2009 NBC, three wires are missing in the 'light circuit' mirror connector T8q pins 4, 5 & 6 - reverse signal, switched 12 volts, and lights on. However, I have found a work around yet to be implemented because I haven't found a tan auto dim mirror. Anyone?
The reverse signal lead just can be grounded without issues, mirror just won't un-dim in reverse. The 12V (ign. on) can be jumpered to connector T10 pin 8 wire or the ckt board. For "lights on" 12V, I plan to use a Radio Shack reed switch connected to the dimmer ckt. T10 pin 7 and ground. Connect the contact to T10 pin 8 and T8 pin 6. Just don't totally dim the dash lights. Of course, one could run these wires from the dash up to the mirror. This seems difficult to me.
Bought a mirror off eBay but sent it back. It had broken plastic, badly faded and looked like it had be worked on with missing screws.
Keep us posted on your progress.
Tom
Going from manual to auto sre2094 Transmission Talk 3 06-22-2009 02:39 AM
Auto TDI vs Gas Manual sideshowbob New Member Forum 9 08-17-2007 01:04 AM
Vert Auto-Dim Mirror on eBay Duffy New Beetle Convertible 1 03-24-2007 08:44 PM
Auto-Dimming mirror swap diabolique Styling Modifications 0 06-13-2006 07:34 PM
