2005 VW Beetle - NewBeetle.org Forums
Old 02-27-2010, 04:14 AM
Default 2005 VW Beetle
Does anyone have any idea why the blinker, horn, and headlights suddenly stopped working on a 2005 VW Beetle?
Old 02-27-2010, 05:40 AM
First, welcome to the org.
It looks like you ignition switch has gone out. It happened to Cup, my new beetle. If you check your fan, it should be out too. You should have use of your bright light if you continue to have it in the flash position.
The ignition switch is in the steering wheel column and is a relatively easy fix. There's several threads here on the org about it. Much success to you and your fix. Keep us posted on what happens.
New Beetle GTG 2005 - 2009 Tommy Photos: Get Togethers 2 11-23-2009 05:44 PM
2005 New Beetle 2005Beetle New Member Forum 17 10-18-2009 10:51 PM
2005 VW Beetle Convertible Jodyboy Market Place Archives 4 02-15-2007 02:52 AM
2005 VW Beetle TDI wmdunn Market Place Archives 3 01-14-2007 08:31 PM
2005 Beetle specs :) The Cheat Technical Modifications 0 09-23-2005 03:14 AM
