Oil pan bolt - NewBeetle.org Forums
Old 03-02-2010, 08:08 PM
Saved2
Grand Rivers, KY, USA
Car: New Beetle 1998
Default Oil pan bolt
Last time I changed oil in my 98 when tightining the drain bolt it seemed to get loose as I tighened it , I thought the last man to change the oil stripted the threads , so is ther a replacement bolt that will cut new threads and where do you get it , Thanks
Old 03-03-2010, 04:41 PM
Saved2
My mechanic says he can fix them he has 3 larger size bolts that cut new threads.
Old 03-03-2010, 05:54 PM
noR's Avatar
Administrator
Jackson, MS, USA
I suppose that'll do.
I'd recommend you drop the oil pan, use a thread tap to cut new threads in a slightly larger size, and then a matching bolt for that. Careful about length.
Also, be sure to pick up ALOT of spare copper washers that fit. it's likely to be more leaky than originally.
noR | me | Phrog
PHROG
Old 03-04-2010, 05:08 AM
OH, USA
Car: 03 GTI
Personally I'd Heli-Coil (tm) or Time-Sert (tm) the oil drain hole.
Old 03-04-2010, 06:48 AM
Fowvay's Avatar
Moderation in Moderation
Berea, OH, USA
Awesome!!!
Thanks for volunteering to do mine.
Old 03-05-2010, 02:49 AM
OH, USA
Car: 03 GTI
Originally Posted by Fowvay View Post
Awesome!!!
What? Didn't Aaron put on a new pan?
Old 03-05-2010, 09:50 AM
simonsi's Avatar
Jitterbug
Auckland, New Zealand
Car: 2000 NB 2.0
I´d go for a new pan but maybe that is just me.... thread repairs can work or they can be never quite right....
Cheers
Simon
Old 03-05-2010, 01:29 PM
Fowvay's Avatar
Berea, OH, USA
Ya but... I kinda want to sell the old pan and I'm... err... lazy.
Old 03-06-2010, 01:13 AM
OH, USA
Car: 03 GTI
Oh, I didn't think of that. Yeah, I could do it sometime--if you get the kit--but it's very easy, especially when you don't have to do it on the car and worry about shavings getting in th engine. I've done spark plug holes on cars and motorcycles and Type 1 cases with helicoils.
Old 03-06-2010, 01:29 AM
Fowvay's Avatar
Berea, OH, USA
I've done it too. I was just kidding, Bill. It's actually about the easiest repair you can make on a car aside from replacing a filter... well... maybe even easier than the air filter on the Focus.
Old 03-06-2010, 01:57 AM
OH, USA
Car: 03 GTI
Yes, but do you think it is easier than attaching a wheel? You know how I did with that.
Old 03-06-2010, 02:18 AM
Fowvay's Avatar
Berea, OH, USA
Third times the charm?
edit:
2 wheels, 1 intercooler pipe.... so fourth time?
Old 03-06-2010, 03:56 AM
OH, USA
Car: 03 GTI
edit:
Ha, well, I never seem to have these problems when I'm working on my car--so maybe I'm just one of those mechanics who just shags it up or just doesn't give a crap (in the back of my mind somewhere?) when working on somebody else's car? You do have to admit though that my hillbilly plastic undertray "repairs" were pretty good...
Old 03-06-2010, 05:43 AM
Fowvay's Avatar
Berea, OH, USA
Those F'n rock and are still holding strong. Much stronger in fact than the rest of that stupid plastic.
Old 03-07-2010, 06:37 PM
FL,
Car: 2002 New Beetle, 20valve Turbo
This is a simple problem, and an easy fix. Go to local Auto Zone and ask for a self taping oil plug ( take the old one with you )you will find there are several sizes, get the one next to standard. Grease the plug and screw it in then remove it and clean the metal off and reinstall it.
Old 03-08-2010, 01:42 PM
simonsi's Avatar
Jitterbug
Car: 2000 NB 2.0
Hmmm - is it easy to cross thread those whenever they are removed and refitted though? I would think it is forever easy to cut a new thread - or do you just go up a size of bolt on any future oil change???
Old 03-08-2010, 01:53 PM
macdave's Avatar
Olympia, WA, USA
Car: 01 1.9TDI Techno Blue
you can get a new oil pan with a steel bottom. then the plug goes into steel threads.
Old 03-08-2010, 06:31 PM
Albuquerque, NM, USA
Car: 2003 GL TDI
And now you know why the car is designed to have motor oil vacuumed out the dipstick tube!
Kent Christensen
Albuquerque
'03 GL TDI, '07 GL320CDI, '06 E320CDI
Old 03-08-2010, 07:11 PM
I would think if it were designed for that, then there wouldn't be a drain plug. Pretty sure that the Bentley says to drain it from the bottom. Plus, its a lot easier to get all of the old oil out via gravity than fighting gravity and using a vacuum. And you also still have to get under the car to remove the oil filter so why not do everything at once in one place?
Its easy to mess up and strip bolts. You just have to be careful. If I had mine stripped, I would probably just invest in a new oil pan. Make sure that the bolt is nice and tight in there and not risk leaking from a fix that might not entirely work.
Old 03-12-2010, 02:10 AM
OH, USA
Car: 03 GTI
"designed to have motor oil vacuumed out the dipstick tube" Sorry, but it's not.
Stripped bolt help lawlesseyes Questions, Issues, Concerns, or Problems with the New Beetle 2 07-15-2009 01:32 PM
stripped bolt help! lawlesseyes 1.8 Liter Turbo 2 07-13-2009 09:12 PM
WTB: Battery Bolt And Box FallinApartBoy Parts and Accessories 1 01-31-2009 08:07 PM
Broken Bolt jc918t 1.8 Liter Turbo 2 07-02-2007 11:15 AM
Help!!How do you get the bolt out of the battery? beetlebabe25 2.0 Liter Gas 5 01-04-2007 02:52 PM
