.....IS A PAIN IN THE A$$!!!
Some of you might have once seen this on their car: ![]() Not a biggy you think, go to the dealer and buy a fresh set of lights and just swap them out, how bad can that be. Well, after studying the situation for five minutes I found out that you have to remove the whole freakin' front of the car and you know what the hardest part was? Getting those headlights out, after sitting comfortable in their little frame for almost ten years they weren't very helpfull in the removing process. Believe it or not but this is how your car looks like when you replace the fog lights: ![]() Of course when it's done you forget about it pretty soon and life is good again: ![]() Well, almost then, some adjustments might be neccessary but hey, how hard can that be....... Arthur |
Someone correct me if I'm wrong
If your NB was assembled from M.Y. 98 through June 2000, you needed to remove the entire front end assembly, as shown in the pics, in order to replace the fog light assemblies.
Assembly dates from July 2000 through June 2005 changed and you only need to remove the lower grille assembly to access the fog lamp assemblies. So, Atjoer, if your NB really is 2001.5, you did not have to remove the entire front end assembly. That was a lot of work that really didn't need to be done. Check the actual manufacture date on the door pillar to verify the date. At any rate, bulbs can be replaced without having to remove anything. Just reach up and remove the rubber boot around the rear of the foglight, turn the cover counterclockwise and pull the bulb mount out, replace bulb, reinsert cover, lock and put the boot back on and you're good to go. Hope this helps. ![]() |
Our 98 was a base model (early VIN) w/o fogs and I wanted to add them. Bought the appropriate 3 pc grille/valance/light bar combo as well as 2 new lights. Gently pryed the old non fog valance out, assembled the new fog valance and snapped it into place. I did drill two small holes in each lower corner and used zip ties just to be sure it stayed in place. I tried looking for pics I posted when I did the job, but can't find them.
I don't have to be ashamed of the car I drive. I'm just glad to be here, to be alive.... Travelling Wilburys Why do we drive on Parkways, but park on driveways......Credit: someone from the model T forum |
NewBeetle.org Forums - Search Results
Check the top two How-To's. Michelle has a good step by step and the one that Bugart did is really descriptive.
I replaced both foglights with an offset rachet screwdriver. It took a while, but it beat removing the front clip! There's two phillips head screws driven from the top down into the plastic frame of the foglight.
Sorry to highjack the thread , but has anybody replaced their factory fog lights with aftermarket lights? Its an idea I have been kicking around as I have HID headlights and have seen some foglights advertised that look like HIDs .
Jer
2000 Beetle GLX 1.8T in Cyber Green, TSW wheels, Forge 007 DV, Altezza tails, halo fogs, clear corner lights, tint, Kenwood head, Alpine speaks, JL subs, RF amp, carbon dash kit, antenna, and pedals, custom racing stripes, Cyber Green calipers, Cyber Green dash and console, Monster Mats |
haha, i just took the grill out and pilled the stockers off. then again i wasnt converned about using tin snips or whatnot, i was changing fogs completley to some 4.5 inch HID fog/driving lights. :-) ended up modding the grill with some "grill" wire(had a diamond patern on it, actually got it at a grill shop...) and you didnt even know i had fogs until they were turned on.
Matt
"DIVINE INSANITY: God killed himself on the cross to save his own creation from his own wrath"-----Author unknown turbo S: $200.37 a month intake: free K&N Xstream: $80.00 embarassing every ricer within 50 miles: PRICLESS! |
sorry no pics. but i just mounted the lights to the Radiator brace and used the grill frame to mount the new grill. a bit of flat black rattle can and BAM, sexyness.
| Tail Lights not working after replacing Brake Lights | megepo0 | Questions, Issues, Concerns, or Problems with the New Beetle | 3 | 05-21-2011 12:04 PM |
| Please help! Can a package 2 beetle convertible 2007 not have fog lights | Joe Cat | Styling Modifications | 1 | 11-29-2009 02:29 PM |
| 99 Beetle Fog lights | ramprat | Styling Modifications | 1 | 11-13-2009 08:02 PM |
| Replacing Fog Lights on a 2002 Beetle | sgtstadanko | Technical Modifications | 4 | 11-13-2007 02:14 PM |
| wanted beetle fog lights | StealthTurbo | Market Place Archives | 0 | 12-09-2005 06:24 AM |
