Q's about my new ScanGauge II - NewBeetle.org Forums
Old 07-29-2010, 01:46 AM
PeachyPeach's Avatar
Insert clever epithet
USA
Car: 2000 Silver Arrow GLS 2.0L 5 speed
Default Q's about my new ScanGauge II
Hey, I just got a ScanGauge II, and I have questions for the other ScanGauge owners about setup and normal operating values.
1. Water temp in upper 180s to lower 190s is normal, right?
2. Voltage ranges between 11.6 and 14.3 or so while it's running. Reasonable?
3. Our fuel tanks are 14.5 gallons, it allows 14 or 15. How did you all set it up?
4. MPH doesn't match--it's about 3 below the dash gauge at 60 and 5 below at 80. It's not the lag, I held those speeds for several miles. I've heard the needle is high from the factory, but this high?
5. When I plug the cable in the back, it works. When I plug it in the side, it never connects; the manual doesn't mention the side port at all, and the quick start guide just says it's an optional port. Is this normal, or a defective unit? I admit I didn't try any troubleshooting steps on it since the back one works.
Thanks!
Old 07-29-2010, 01:53 AM
Fl_bug's Avatar
Catch me riding s00ty!
Miami, FL, USA
Thanks!
Let me know how you like it! I'm debating on getting one eventually! Ohhh, and i'm really curious about the distance to empty feature on that thing!
Oh and on number 4, yeah thats normal unfortunately. I know because my neighborhood sometimes sets up those signs with a radar gun and it shows your speed. One time I was going 3mph over (or so I thought) and it said I was going 1mph under the speed limit. So there is a decent margin of error to our speedos.
Old 07-29-2010, 02:13 PM
New to VDubs, not to cars
Morrisville, NY, NY, USA
Car: 2002 Turbo S Beetle
I can also verify the speedo discrepancy.
Our TomTom GPS showed the same inaccuracy.
By any chance can you read boost pressure with the gauge?
Do you have a complete list of the data it can display
Also, I'd set it for 14 gallons, that way you have that 1/2 gallon reserve just to safe.
Old 07-29-2010, 06:00 PM
marvins_dad's Avatar
I BELIEVE!
Dallas, TX, USA
Car: 2002 DIYCGCC TDI
I have one...will be finally installing this weekend, I will check your numbers once I have it installed.
Where did you end up installing yours? Mounting the box?
marvins_dad ~ antoine
Old 07-29-2010, 07:38 PM
USA
I actually bought it to help me monitor the effects of a slow coolant leak and a very large car stereo setup. I haven't messed with the fuel economy stuff all that much yet, but it's on my to-do list. So far I like it, Fl_bug. It does what I bought it for--peace of mind that my car is running at a sane temperature--but there are minor gripes: it doesn't refresh the data that quickly (every second or so, which is a long time at highway speeds). So the speedo really is that far off, by design. Wow.
Originally Posted by marvins_dad View Post
...Where did you end up installing yours? Mounting the box?
Thanks in advance. I have a temporary install right now, with the cable coming up between the passenger seat and the e-brake surround. Not the most visible location, but it stays put surprisingly well. I plan to mount it under the hazard/rear defroster buttons and run the cable under the dash like other people have done, but I'm not sure how to mount it yet--I hate Velcro. For now I'll cable tie it. I'm thinking about attaching an angle bracket to the back of the unit (I haven't opened it up yet to see how much extra space is inside; maybe with screws, otherwise epoxy) and screwing it to the car. I already had an OBD-II scanner, so it doesn't need to be portable.
Originally Posted by VDub Dan-O View Post
...By any chance can you read boost pressure with the gauge?
I have a 2.0 *shrug* but this is what you want to know. Setting it to 14 gallons is a smart idea.
Old 07-29-2010, 07:53 PM
miffmole's Avatar
NBC Driver
SC, USA
ScanGauge II
Old 07-30-2010, 05:41 AM
macdave's Avatar
Olympia, WA, USA
Car: 01 1.9TDI Techno Blue
both plugs should work, there is no difference between them just for mounting convenience.
Old 07-30-2010, 04:13 PM
USA
Hmm. Ok, thanks.
Old 07-30-2010, 09:10 PM
72SuperBeetle's Avatar
Wienerdude
Elk Grove Village, IL, USA
Car: 03 1.8t Beetle, 01 Jetta 2.0
i thought the side port was for daisy-chaining multiple scangauges together.
I swear my real name is not "Wienerdude"
2003 1.8T Beetle
2001 Jetta 2.0
Old 07-30-2010, 10:29 PM
USA
FWIW, I tried the side port again today and it worked, but it took a lot longer to connect. I'll keep an eye on it and see if that continues.
Old 07-31-2010, 04:11 AM
I BELIEVE!
Dallas, TX, USA
I thought it was for mounting convenience too. Could have sworn that it mentions that in documentation.
I'm hoping I can find an alternate location than over the cup holders, they still slightly function, mounting there will ruin any functionality that is left.
Old 08-02-2010, 02:55 AM
I BELIEVE!
Dallas, TX, USA
Here are some pics...I haven't entered the gallons yet for the tank though.
I have a TDI so my numbers might be different from yours.
Old 08-03-2010, 11:11 AM
Wienerdude
Hey, check out this thread. It may give you some mounting ideas... Mounting Scanguage II
Old 08-03-2010, 12:15 PM
I BELIEVE!
Dallas, TX, USA
I forgot to post the pictures of where I have mine temporarily mounted...
I would rather mount it on the dash next to the gauge pod on the left hand side between the defrost and the cluster, but I would want to fab something that would hide the cable.
Old 08-03-2010, 01:05 PM
macdave's Avatar
Olympia, WA, USA
I put mine right on top of the steering column. The wire comes out right under the cluster, I put it in there when I replaced all the dash panels.
Old 08-03-2010, 07:02 PM
I BELIEVE!
Dallas, TX, USA
Scanguage II settings. - Page 5 - TDIClub Forums
You can scan this thread for the alteration settings for MPH if you want to adjust that setting to read more accurate.
Old 08-12-2010, 07:41 PM
Exclamation Almost bought one........but then
I too have been looking at this scantool and I was so close to buying it. But then I saw something better advertised on one of the Discovery channels. Its called UltraGauge or ultra-gauge or some variation (google it). Ultra-gauge has a much bigger display, displays more gauges at once, and does more stuff. And here is the kicker, its 1/4th the price @ $39. It does so much stuff, I have not figured it all out yet.
I was hesitating on the scanguage because of the price...but now I can buy one for both my vehicles and still come out way ahead!
Old 08-13-2010, 12:55 AM
Found it: UltraGauge Automotive Information Center and OBDII Scan Tool
Seems almost too good to be true
Old 08-13-2010, 01:20 AM
miffmole's Avatar
NBC Driver
SC, USA
Wow, that looks pretty slick. If it does half of what it says, it's quite a bargain at that price.
Buy it and give us a review!
Old 08-13-2010, 06:08 PM
I was going to tell you to try it first.
ScanGauge II miffmole Technical Modifications 13 04-17-2009 02:19 AM
ScanGauge Manifold Absolute Pressure MAP OhioBuckeyeBeetle 1.8 Liter Turbo 0 01-29-2009 08:32 PM
Q's About Driving Lamps Frapp 2.0 Liter Gas 3 01-20-2007 12:15 AM
ScanGauge II dgoldbe2 Miscellaneous Hoo-Ha Archive 4 06-18-2006 07:35 PM
