E3 Spark Plugs - NewBeetle.org Forums
Old 08-24-2010, 04:47 AM
Dakota's Avatar
Owner of Herbert!
Calgary, Alberta, Canada
Car: 98 New Beetle - 02 Dodge Dakota Sport 4X4 Quad Cab
Default E3 Spark Plugs
So I just picked up a set of the E3 spark plugs , and will put them in when I get the chance into my 2.0L bug engine . Is any body using these? Do they work as good as they claim? Any issues? Just curious . Let me know . Thanks . Dakota
Old 08-31-2010, 12:49 AM
Canadianbugin's Avatar
Canadian New Member
Toronto, Ontario, Canada
Car: 98 N.B. 2L 5speed
I have not used them... I just use the stock NGK ones... Let us know if they work out for ya and don't cause any misfires..
Old 08-31-2010, 05:07 AM
JaceyMelissa's Avatar
Jace
MI, USA
Car: 2000 beetle 1.8turbo
I have tried them and did not like them at all. I had them installed right after getting my head all rebuilt( all new valves) and they started to foul out after 10,000 miles. I took them back to the store a nd got new ones(lifetime warranty) and the new ones did not seem to last any longer before they started to foul out. I talked to my mechanic and he told me just to go to diffrent plugs. I am back to running with bosch. E3 did not warranty the second set unless I wanted to send them to their factory for testing, and then maybe they would send me a new set. I think that they are a waste of money for the price. they might run better in other cars. we put them on a wire wheel and put them in a friends KIA and it runs fine. Good Luck
ps I tried them on a 1.8turbo maybe they just don't like the heat.
Old 09-02-2010, 07:04 AM
Dakota's Avatar
Owner of Herbert!
I was going to install them the other day , but looked and found the intake is going to make it difficult for a quick install - I might just wait until I take the intake off to fix my valve cover leak .
Old 10-02-2010, 09:28 PM
Niagara Falls, NY, USA
Car: 2003 Mercury Marauder
I've used the E3 spark plugs for over20k without any problems. Now, that's in my Grand Marquis. Not exactly the same platform. But they've been working well for me.
-ryan s.
Old 08-31-2011, 03:29 AM
IndyTom's Avatar
Indianapolis, IN, USA
I used them in my 2004 Audi TT 1.8T 225 and they ran fine. The car was chipped and I ran one heat range cooler than stock.
Prior to that I ran the NGK Copper ones for 10 bucks a set. To be honest I really didn't see a difference in either performance or gas mileage. I haven't tried them in the 1.8T Beetle yet and probably won't. I got the Beetle REVO Tuned and am running NGK copper plugs in it. Seems to run fine.
Old 10-04-2011, 02:50 PM
Slanesville, WV, USA
Car: 1999 New Beetle 2.0 5speed
I've been running them in my Acura Integra with a swapped B20 and love them, not sure if they are really worth the $5 each but it did smooth out the idle in my little Acura and add some throttle response.
Spark Plugs on a 2.0L digifant_gli 2.0 Liter Gas 14 05-08-2012 07:20 PM
Getting to spark plugs dermusikman 2.0 Liter Gas 12 12-25-2009 11:23 PM
Spark plugs mirciov 2.0 Liter Gas 4 10-27-2009 02:00 PM
70+ hp from spark plugs? Fowvay Questions, Issues, Concerns, or Problems with the New Beetle 17 09-21-2006 02:25 AM
Spark Plugs SIX SPEED 1.8 Liter Turbo 25 11-19-2005 01:34 AM
