Ultra-Gauge.com - NewBeetle.org Forums
Old 09-08-2010, 06:06 PM
miffmole's Avatar
NBC Driver
SC, USA
Default Ultra-Gauge.com
In another thread, bettle765 mentioned an alternative gauge to the ScanGauge known as the Ultra-Gauge (see UltraGauge Automotive Information Center and OBDII Scan Tool)...
The price at the time was $39.95! Now it's $59.95. Anyway, at that price I thought I'd give it a look, even though I already own a ScanGauge.
It came in yesterday. It's great! And at only 37% the price of a ScanGauge...
The Ultra-Gauge touts "74 possible gauges," depending on your make and model of car. My 2004 NBC 1.8T supported the following gauges:
· Open/Closed Loop Emissions Status
· Percent Engine Load
· Engine coolant temperature
· Short Term Fuel Trim Bank 1
· Long Term Fuel Trim Bank 1
· RPM
· MPH
· Ignition Timing Advance
· Intake Air Temperature
· Mass Air Flow Sensor output in grams/sec
· Absolute Throttle Position Percentage
· Bank 1 Oxygen Sensor 2 Voltage
· Mass Air Flow 2, Calibrated/Calculated
· Instantaneous Miles Per Gallon (MPG)
· Average Miles Per Gallon (MPG)
· Average Miles Per Hour (MPH)
· Average Gallon Per Hour (GPH) - general
· Run Time - general
· Distance - general
· Fuel Used - general
· Intantaneous Gallons Per Hour (GPH)
· Fuel Tank Gallons Remaining
· Distance to Empty(DTE)
· Time to Empty (TTE)
· Volumetric Efficiency (MAP vehicles only)
· Average MPH - trip
· Average MPG - trip
· Fuel Used Gallons- trip
· Average Gallon Per Hour (GPH) - trip
· Run Time -trip
· Distance - trip
· Oil Distance
· Service Distance
· UltraGauge Temperature
Here are a couple of photos of it installed in my car:
Old 09-08-2010, 08:34 PM
pm22071985's Avatar
USA
Does it monitor volts?
Display error codes & clear them?
Old 09-08-2010, 08:42 PM
dmbluebeetle's Avatar
Blue Hunter
Riverside, OH, USA
Car: Blue '04 N. B. Turbo GLS
Found this on their site
UltraGauge not only displays all current vehicle trouble codes but also codes for potential or intermittent faults. With UltraGauge, checking engine codes is easy. UltraGauge also proactively scans for trouble while you are driving and alerts if trouble is found.
UltraGauge uses the same fundamental technology that automotive mechanics use and can display all current vehicle trouble codes. Eliminate the hassle, time and expense of taking your vehicle to an automotive repair center. Repair centers charge $50 or more to read trouble codes.
Avoid faults that can lead to expensive and untimely break downs.
Many states are now eliminating the need for traditional tailpipe-based smog testing and are moving to examining trouble codes to determine the emission status of vehicles. By knowing your vehicle has no existing or pending trouble codes, your vehicle is likely to pass with ease.
Check Engine Light on?
No problem !
UltraGauge can also turn off that annoying check engine light !
Old 09-08-2010, 08:55 PM
pm22071985's Avatar
USA
Cool. thanks.
It also listed voltage on there website, I just didn't see it in miffmoles post.
Old 09-08-2010, 08:57 PM
miffmole's Avatar
NBC Driver
SC, USA
The Ultra-Gauge doesn't seem to monitor volts on my car, although the ScanGauge does, so I know the Beetle supports it.
It does display error codes and clears them.
Old 09-08-2010, 08:59 PM
miffmole's Avatar
NBC Driver
SC, USA
Here's the User Manual:
http://ultra-gauge.com/ultragauge/su...ser_manual.pdf
Old 09-08-2010, 09:02 PM
pm22071985's Avatar
USA
dude that sucks, i was just about to pull the trigger on one of these but have grown very worrysome of my alternators so I like to moniter volts.
I have 2 scangauges and they both moniter the volts, but would like a little variety and thought maybe this would go in my third bug.
I'll email them to see if they can answer specifically. they probable won't.
Old 09-08-2010, 09:06 PM
pm22071985's Avatar
USA
hmm, they hide there email address....
price is also 68$ but you get 9$ refund.
Old 09-08-2010, 09:20 PM
miffmole's Avatar
NBC Driver
SC, USA
Yeah, there's a rebate form via USPS, and some user data you have to send them via Internet.
Old 09-09-2010, 05:55 PM
Evanrude's Avatar
~Feel the Sting~
Longview, WA, USA
Hm... according to the gauge info on the site...it does support voltage. That should pretty much be usable on any car since it is plugging into your electrical supply in order to work.
  • % Engine Load
  • Engine Coolant Temperature (ºF)
  • Short Term Fuel Trim Bank 1
  • Long Term Fuel Trim Bank 1
  • Short Term Fuel Trim Bank 2
  • Long Term Fuel Trim Bank 2
  • Fuel Pressure (PSI)
  • Intake Manifold Absolute Pressure (PSI)
  • RPM
  • MPH
  • Timing Advance
  • Intake Air Temperature (ºF)
  • Mass Air Flow Sensor 1 (g/s)
  • Absolute Throttle Position 1 %
  • Bank 1 0xygen Sensor 1 Voltage
  • Bank 1 0xygen Sensor 2 Voltage
  • Bank 1 0xygen Sensor 3 Voltage
  • Bank 1 0xygen Sensor 4 Voltage
  • Bank 2 0xygen Sensor 1 Voltage
  • Bank 2 0xygen Sensor 2 Voltage
  • Bank 2 0xygen Sensor 3 Voltage
  • Bank 2 0xygen Sensor 4 Voltage
  • Run time since last Start (hours:mins)
  • Distance traveled with Check Engine Light On.
  • Fuel Pressure (Diesel)
  • Bank 1 Wide 0xygen Sensor 1 Lambda
  • Bank 1 Wide 0xygen Sensor 2 Lambda
  • Bank 1 Wide 0xygen Sensor 3 Lambda
  • Bank 1 Wide 0xygen Sensor 4 Lambda
  • Bank 2 Wide 0xygen Sensor 1 Lambda
  • Bank 2 Wide 0xygen Sensor 2 Lambda
  • Bank 2 Wide 0xygen Sensor 3 Lambda
  • Bank 2 Wide 0xygen Sensor 4 Lambda
  • EGR Flow %
  • EGR Flow % Error
  • Evaporative Purge %
  • Fuel Level % of full
  • Number of Warm-ups since Check Engine Light Cleared
  • Distance traveled since Check Engine Light Cleared
  • Evaporative System (PSI)
  • Barometric Pressure – Inches of Mercury (inHg)
  • Catalytic Converter Bank 1 Sensor 1 Temperature (ºF)
  • Catalytic Converter Bank 2 Sensor 1 Temperature (ºF)
  • Catalytic Converter Bank 1 Sensor 2 Temperature (ºF)
  • Catalytic Converter Bank 2 Sensor 2 Temperature (ºF)
  • Battery Voltage
  • Relative Throttle Position %
  • Outside Ambient Air Temperature (ºF)
  • Absolute Throttle Position 2 %
  • Accelerator Pedal Position 1 %
  • Accelerator Pedal Position 2 %
  • Command Throttle Position %
  • Engine Oil Temperature (ºF)
  • Mass Air Flow Sensor 2 – Calculated
  • Instantaneous MPG
  • Average MPG – General
  • Average MPH – General
  • Run Time – General
  • Distance – General (miles)
  • Fuel Used – General (Gallons)
  • Average Gallons/Hour - General
  • Fuel Level
  • Instantaneous Gallons/hour
  • Distance to Empty (miles)
  • Time to Empty
  • Volumetric Efficiency (MAP vehicles only)
  • Average MPH – Trip
  • Average MPG – Trip
  • Fuel Used – Trip (Gallons)
  • Gallons per Hour (GPH) – Trip (Gallons)
  • Run Time – Trip (Hours:Minutes)
  • Distance -Trip (miles)
  • Oil Change Distance (miles)
  • Service Distance (miles)
  • UltraGauge Internal Temperature (ºF)
Old 09-09-2010, 06:03 PM
miffmole's Avatar
NBC Driver
SC, USA
Sounds reasonable, but...Battery Voltage isn't showing up on my menu. I wish it did. The actual number of the available 74 gauges varies from car to car. Mine can access 34 out of the 74.
Old 09-09-2010, 06:22 PM
Fl_bug's Avatar
Catch me riding s00ty!
Miami, FL, USA
Fuel Level
Time to Empty
I'm interested in it because it tells you this. But i'm wondering how accurate these are? I'd be afraid if it said Time to empty, 60seconds and at 0 the car clunks out...
Old 03-19-2011, 12:46 AM
Melbourne, Australia
Great alternative to a scanguage, anyone tried it on metric units? The website says no metric.
Old 03-19-2011, 06:26 AM
Cooky's Avatar
Every one calls me Fuzzy
Loudon, TN, USA
Car: 1998 VW New Beetle and 2000 Jeep Wrangler
This looks cool tho if you have an android powed phone you can get a app I beleave it is called torque the pic is of a cel. you need to buy a 15 to 20 $ blue tooth plug for your OBD2 plug and everytime you get in you car it will sink and show about the same stuff. It is free or there is a 5$ one that has more. Just letting you know what i have found. I have not tested this i was looking for when i got my droid. If someone testes it please let me kno how it works.
2k12 TOD
Camping At the Top 2k12
"slow is smooth, smooth is fast"
Old 03-19-2011, 12:31 PM
New to VDubs, not to cars
Morrisville, NY, NY, USA
Car: 2002 Turbo S Beetle
I'm ordering the Bluetooth interface today so I will update everyone with the Torque app as well.
Originally Posted by Wingnut_rb View Post
I would get used to the comparison. "This isn't the vortex" is his favorite thing to say!
Old 04-19-2011, 03:16 AM
Cooky's Avatar
Loudon, TN, USA
any update on how the torque worked?
Old 04-19-2011, 11:27 PM
Believe it or not, I'm still waiting for the interface.
Old 04-28-2011, 06:49 PM
Ft. Wayne, IN,
Car: 00 TDI NB
any update on this, i'm actually kinda curious as well.
edit: the bluetooth dongle to a droid that is
Old 04-29-2011, 07:27 PM
Minneapolis MN, MN, USA
Car: 2002 VW NB Turbo S
I have an ultra gauge and must say that I love it. I mostly like the correct MPH and engine temp. Other then that it works well and so far has been used for about 4 months with no issues what so ever.
Old 05-05-2011, 01:08 AM
Had to file a complaint and got a refund.
more ultra vw bug boogie pics porschtrimr Photos: Get Togethers 5 10-01-2007 05:28 AM
Ultra-Safe Wheel Spoke Brush BlueMartian New Beetle Detailing/Cleaning 2 04-15-2006 05:39 PM
··· ¿ ULTRA-EURO ? ··· Staggered 17x8/17x10 ··· ¿ POKE··STRETCH··LIP ? ··· Bef Market Place Archives 0 12-12-2005 03:18 PM
Ultra rare Blue New Beetle RSI phope Miscellaneous Hoo-Ha Archive 50 11-04-2005 04:02 PM
