VAG-COM adaptation question disabling seatbelt warning. - NewBeetle.org Forums
Old 09-09-2010, 09:53 PM
Beltaine's Avatar
Default VAG-COM adaptation question disabling seatbelt warning.
So, I went to disable the seatbelt warning.
My current Channel 17 is '11232'
According to Ross-Tech, I would need to change it to '05232'
When I do that, the seat belt warning turns off, but then the spoiler light illuminates. I have a convertible... no spoiler.
So... figuring the seatbelt warning is a value of 02 and the first 2 digits are the sum of all the values of equipment you want enabled, I plugged in '09232'
This resulted in no change to the seat belt warning, but didn't trigger the spoiler light.
Any ideas? I put it back to the default of '11232' for now.
Are the first two digits a hexadecimal value? Would 11-2=0F?
disabling warning chimes Goranothos Technical Modifications 2 07-23-2010 05:40 PM
vag com question dirtyleft 2.0 Liter Gas 2 07-16-2010 08:00 PM
Seatbelt warning and center console questions. Turbobeetleconv05 Questions, Issues, Concerns, or Problems with the New Beetle 5 08-30-2008 03:29 PM
vag-com question a_magoo Questions, Issues, Concerns, or Problems with the New Beetle 2 07-17-2008 04:35 PM
passenger seatbelt warning STDave Questions, Issues, Concerns, or Problems with the New Beetle 8 02-21-2007 05:15 AM
