Few quesitons about possible exhaust purchase - NewBeetle.org Forums
Old 09-11-2010, 10:57 PM
AbuNigel's Avatar
buggin
Bridgeport, CT, USA
Car: 2000 2.0L Red New Beetle GL
Default Few quesitons about possible exhaust purchase
So i want to get a magnaflow catback exhaust.
I don't really like the under the bumper look, but i hear drone is awful with turn down tips, if i got them welded in instead. Would it be hard to make a cut out in the stock bumper? i've seen it done (YouTube - beetle turbo)
Also is this an install job I could do on my own? My understanding is that it just requires cutting the stock exhaust pipe which can be a pain, but still doable.
My 2.0: 'Lil Red'
Old 09-12-2010, 04:39 PM
connieray's Avatar
Pisant
Lakehills, TX, USA
Car: 2000 GLS, 2002 GLX, 2004 NBC
Smile
I put a Magnaflow catback on my 2000 about 4 years ago. I used the neighbors's lift, and had it done in under 30 minutes. I did use a sawsall to cut the factory tail pipe where the bend is. Sounds great.
Old 09-13-2010, 06:39 PM
The actual exhaust install is not terribly difficult, the Magnaflow systems fit extremely well and removing the stock exhaust is usually more work than installing the new one.
As far as the bumper goes... It can be very difficult to get a nice looking exhaust cutout, but it is certainly possible. I've found in the past that using some painters tape to mask out the area you want to cut really helps in getting a clean shape, getting the corners smoothed out, etc... is a bit more work.
We do have the Magnaflow systems available for the 2.0L New Beetle here on the website:
Volkswagen New Beetle 2.0 > Exhaust > Cat Back
Old 09-13-2010, 10:54 PM
connieray's Avatar
Pisant
Lakehills, TX, USA
Smile
Jon at ECS is correct, it takes longer to take the old exhaust off than putting on the new Magnaflow exhaust. It is very easy to do.
Mine has been on for 3 or 4 years and the sound is great. Mine has the original Magnaflow 3" exhaust tips that are welded to the rear muffler and they look great. You can tell they are not those cheapo bolt on's. And they have Magnaflow stamped on both tips. They point straight out.
The stainless still looks great with no discoloration. I go to a lot of car shows and when you look at the driver's side rear wheel opening you can see that the rear muffler is stainless and no discoloration. Looks like new.
There probably is cheaper stuff out there, but they can't have the quality.
Go for it.
Old 09-14-2010, 03:32 PM
AbuNigel's Avatar
buggin
Bridgeport, CT, USA
ok, so doable with just jack stands though?
Old 09-14-2010, 03:55 PM
Yes, installation is certainly possible with just jack stands.
Old 09-14-2010, 05:16 PM
AbuNigel's Avatar
buggin
Bridgeport, CT, USA
great, thank you!
Old 09-15-2010, 05:56 PM
70autostick's Avatar
VW Junky
Car: 1999 GLS 2.sl0w
Just to throw this in there, i installed a Magnaflow catback on my 2.0 last week.
It was a great purchase, sounds great on the 2.0s, no high notes at all! Sounds very beefy.
I went with the split pipe under the bumper, looks pretty sweet.
Old 10-17-2010, 10:53 PM
VA, USA
Car: 99 VW Bug Black
Will the ANSA listed above on ECS fit? I have a 99 auto 2.0??
Old 10-18-2010, 12:15 PM
Yes, the ANSA system would fit a 1999 2.0 auto:
Old 12-19-2010, 02:12 PM
VA, USA
Hey I was checking out the exhaust on you tube and noticed the tips stick out exceptionally far from the rear is this the case and about how far I have a 99 NB and if so is there a way to mod the length of the tips?
Looking into purchase OtakuAnonymous Questions, Issues, Concerns, or Problems with the New Beetle 12 03-13-2010 09:59 PM
Tr: 42 Draft Designs 3" TB Exhaust for stock Beetle Turbo S Exhaust (Chicago) r0nd3L Parts and Accessories 2 12-12-2008 11:10 PM
About To Purchase FLASH13 1.9 Liter TDI 13 09-07-2006 04:50 AM
Caractere/Remus exhaust sounds like factory...want exhaust with some sound phinsfan99 Technical Modifications 0 08-26-2006 02:23 PM
Looking To Purchase! SunshinesFunshine Market Place Archives 10 07-03-2006 02:02 AM
